Hey Guys,
I'm trying to convert a stack of old VHS tapes to DVD using Diamond VC500 to capture audio/video to Mpeg2
Capturing seems fine, but when trying to encode and author the DVD sometimes it works fine, other times I get errors.
Many of these tapes convert to larger than 4.7gb, so I am using DVDshrink to compress.
Since this is old VHS quality is not a huge issue, but the less loss the better obviously.
Here is the error that I get from AVStoDVD during the authoring process:
Process aborted during DVD AUTHORING operations!
DVD Authoring operation failed, probably caused by excessive bitrate.
Decrease video and/or audio bitrates and then retry the project.
Check following files for more details:
AVStoDVD log file <C:\Users\owner\Videos\DVD_1.log>
BatchMux log file <C:\Users\owner\Videos\DVD_1_BatchMux.log>
can you walk me thru the process to reduce the bitrates, if that is indeed the problem?
	Here is the log file:
 <2/13/2018 8:51:32 PM>
 START PROCESS
 PROJECT SETTINGS
 DVD Video Standard: NTSC
 DVD Titles number: 1
 DVD Size: 4103/4450 MB (92%)
 DVD Output Setup: DVD Folder
 DVD Label: DVD
 DVD Menu: No Menu
 Output Folder: C:\Users\owner\Videos
 Delete Temp Assets Files: Yes
 Delete Temp Working Files: Yes
 Edit Command Parameters: No
 Post Process Task: Show Progress Status window
 PREFERENCES
 MultiThread: 1
 AVS Video Source Filter: A2DSource
 AVS Audio Source Filter: A2DSource
 AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
 Frame Adjust Strategy: 0
 FPS Hard Conversion: 1
 PAL SpeedUp: 0
 NTSC SlowDown: 0
 Video Resolution: 0
 Video Encoder: 0
 Video BitRate Min: 2500
 Video BitRate Max: 8500
 Keep DVD Compliant Video: 1
 AC3 Audio Encoder: 0
 Force FFmpeg for Long Audio: 1
 DVD Audio Format: 0
 DVD Audio BitRate: 192
 Keep DVD Compliant Audio: 0
 Normalize Audio: 0
 Auto Delay Audio: 1
 DVD Audio Language (Primary): EN - English
 DVD Audio Language (Secondary): EN - English
 DVD Subs Language (Primary): EN - English
 DVD Subs Language (Secondary): EN - English
 DVD Subs Font: Tahoma 16pt (240,240,240)
 Chapters Interval: 5
 Use Source Chapters: 1
 DVD Burning Drive: D:\
 DVD Burning Speed: 4x
 Auto Erase DVD RW: 1
 Unload ActiveMovie Library: 1
 Adjust DirectShow Filters at runtime: 1
 Save General Settings: 0
 SYSTEM INFO
 Processor Name: Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz
 Operating System: Windows 10 (10.0.16299) 64 bit
 User has Admin Rights: YES
 Running with Elevated Privileges: NO (3)
 Available Output Disc Space: 128 GB
 AviSynth is installed: YES (release 2.6.0)
 LAV Filters is installed: YES (release 0.70.2)
 ffdshow is installed: NO
 CODECS REPORT
 H.264/AVC: Microsoft DTV-DVD Video Decoder
 Xvid: Mpeg4s Decoder DMO
 DivX 4/5/6: Mpeg4s Decoder DMO
 Other MPG4: Mpeg4s Decoder DMO
 DV: DV Video Decoder
 MPEG1: MPEG Video Codec
 MPEG2: Microsoft DTV-DVD Video Decoder
 AAC: Microsoft DTV-DVD Audio Decoder
 MP3: MP3 Decoder DMO
 MP2: Microsoft DTV-DVD Audio Decoder
 AC3: No Preferred Filter set
 TITLE 1 SOURCE FILES
 Video: C:\Users\owner\Desktop\Converted Video files\H Lorayne CM Vol1.mpg
 Info: MPEG-2 Video - 5296 kbps - 720x480 - DAR 4:3 - 29.97 fps - Interlaced (TFF) - 1:42:08 hours - 183661 frames
 Audio 1: C:\Users\owner\Desktop\Converted Video files\H Lorayne CM Vol1.mpg
 Info: PCM - 1536 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 1:42:08 hours (16 ms delay)
 [MediaInfoLib - v0.7.77]
 AVISYNTH SCRIPT
 Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
 # Video is frameserved by AviSynth just for Preview and Edit purposes.
 Video = A2DVideoSource("C:\Users\owner\Desktop\Converted Video files\H Lorayne CM Vol1.mpg", CacheFolder="C:\Users\owner\AppData\Local\Temp", FrameRate=29.97)
 Audio = A2DAudioSource("C:\Users\owner\Desktop\Converted Video files\H Lorayne CM Vol1.mpg", CacheFolder="C:\Users\owner\AppData\Local\Temp")
 Video = Video.ConvertToYV12(interlaced=true)
 Audio = Audio.DelayAudio(0.016)
 AudioDub(Video, Audio)
 DIRECTSHOW AUDIO MIXER OPERATIONS:
 No LAV Filters mixer ON/OFF adjustment required at runtime
 START VIDEO DEMUXING OPERATIONS
 Video Encoding Profile: Direct Copy (FFmpeg Demux)
 Target Video FileSize: 3869.5 MB
 Demuxing Parameters: -i "C:\Users\owner\Desktop\Converted Video files\H Lorayne CM Vol1.mpg" -c:v copy -an -sn -y "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1.m2v"
 <2/13/2018 8:55:09 PM>
 END VIDEO DEMUXING OPERATIONS
 Created File: C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1.m2v (3887.9 MB)
 Ouput Video Info: MPEG-2 Video - 5317 kbps - 720x480 - DAR 4:3 - 29.97 fps - Interlaced (TFF) - 1:42:14 hours - 183823 frames
 START AUDIO ENCODING OPERATIONS (Track 1)
 Wavi+Aften Parameters: "C:\Users\owner\AppData\Local\Temp\DVD_1_H Lorayne CM Vol1_1.avs" - | "C:\Program Files (x86)\AVStoDVD\Aften\aften.exe" -b 192 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_1.ac3"
 <2/13/2018 8:57:17 PM>
 END AUDIO ENCODING OPERATIONS (Track 1)
 Audio Source Filter: A2DSource - DirectShowSource
 Created File: C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_1.ac3 (140.3 MB)
 Output Audio Info: AC3 - 192 kbps - CBR - 2 ch - 48000 Hz - 1:42:08 hours (0 ms delay)
 DVD CHAPTERS CREATION OPERATIONS
 Title 1 Input Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820
 Title 1 Output Chapters List: 8991 17982 26973 35964 44955 53946 62937 71928 80919 89910 98901 107892 116883 125874 134865 143856 152847 161838 170829 179820
 Created File: C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_Chapters.txt (150 Byte)
 START DVD AUTHORING OPERATIONS
 BatchMux Parameters: -arglist "C:\Users\owner\AppData\Local\Temp\DVD_1_BatchMux. ini"
 BatchMux ini file:
 -bmlog "C:\Users\owner\AppData\Local\Temp\DVD_1_BatchMux. log"
 -d "C:\Users\owner\Videos\DVD_1\VIDEO_TS"
 -mxp "C:\Users\owner\AppData\Local\Temp\DVD_1_MuxMan.mx p"
 -l "C:\Users\owner\AppData\Local\Temp\DVD_1_MuxMan.lo g"
 -muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
 -prio LOW
 -palette "C:\Users\owner\AppData\Local\Temp\DVD_1_Palette.t xt"
 -v "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1.m2v"
 -vidmode 4:3
 -a1 "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_1.ac3"
 -a1lang en
 -cellfr "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_Chapters.txt"
 -progfr "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_Chapters.txt"
 -chapfr "C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_Chapters.txt"
 <2/13/2018 9:00:54 PM>
 For more troubleshooting on Authoring issues, see Help/FAQ/Authoring.
 <2/13/2018 9:01:56 PM>
 Warning! AVStoDVD Project ended with errors.
 Log file created by AVStoDVD Release 2.8.7
	Here is the BatchMux log:
 BatchMux log file --> C:\Users\owner\AppData\Local\Temp\DVD_1_BatchMux.l og
 BatchMux version --> 1.4.1
 Destination Folder --> C:\Users\owner\Videos\DVD_1\VIDEO_TS
 MuxMan Script File --> C:\Users\owner\AppData\Local\Temp\DVD_1_MuxMan.mxp
 MuxMan Log String --> -l "C:\Users\owner\AppData\Local\Temp\DVD_1_MuxMan.lo g"
 Folder of the MuxMan executable --> C:\Program Files (x86)\AVStoDVD\MuxMan
 Check presence of MuxMan.exe --> PASSED
 Palette File --> C:\Users\owner\AppData\Local\Temp\DVD_1_Palette.tx t
 Default Palette --> SUCCESSFULLY REDEFINED
 Segment #1 - Video File #1 --> C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1.m2v
 Checking asset for importing as --> M2V, M1V, MPV
 Video Coding Mode --> MPEG-2
 Video Resolution (Nominal) --> (720x480)
 MPEG-2 Aspect Ratio (DAR) --> 4:3
 Video Frame Rate --> 29,97 fps
 Video Bitrate (Nominal, Kbps) --> 8105
 VBV Buffer Size (Kbyte) --> 224
 Segment #1 - Video Display Mode --> 4:3
 Segment #1 - Audio #1 File #1 --> C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_1.ac3
 Segment #1 - Audio Lang Code #1 --> en
 Segment #1 - Timeframe file --> C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_Chapters.txt
 Segment #1 - Total Nr of Cells --> 21
 Segment #1 - Total Nr of Programs --> 21
 Segment #1 - Total Nr of Chapters --> 21
 Started preparation of --> MUXMAN SCRIPT
 Completed preparation of --> MUXMAN SCRIPT
 MuxMan RunString --> -run
 Strings (local stack - bytes) --> 1186
 Time Codes (local heap - bytes) --> 769
 Static memory usage % --> 1.49
 Starting MuxMan Authoring with --> LOW task priority
 MuxMan Authoring --> COMPLETE
 Printing out --> MUXMAN LOG
 -- MuxMan version 0.16.8
 -- Opened script file C:\Users\owner\AppData\Local\Temp\DVD_1_MuxMan.mxp
 -- Accepted audio C:\Users\owner\Videos\DVD_1_H Lorayne CM Vol1_1.ac3
 -- 20:57:29 Begin multiplex VTS01.
 -- Title Segment List
 -- Seg1
 -- Maximum audio duration 367324 fields.
 -- Starting scene Seg1_Scn1 at 00:00:00:00
 -- Starting scene Seg1_Scn2 at 00:04:59:28, requested for 00:04:59:21
 -- Starting scene Seg1_Scn3 at 00:09:59:13, requested for 00:09:59:12
 -- Starting scene Seg1_Scn4 at 00:14:59:13, requested for 00:14:59:03
 -- Starting scene Seg1_Scn5 at 00:19:58:28, requested for 00:19:58:24
 -- Starting scene Seg1_Scn6 at 00:24:58:28, requested for 00:24:58:15
 -- Starting scene Seg1_Scn7 at 00:29:58:13, requested for 00:29:58:06
 -- Starting scene Seg1_Scn8 at 00:34:57:28, requested for 00:34:57:27
 -- Starting scene Seg1_Scn9 at 00:39:57:28, requested for 00:39:57:18
 -- Starting scene Seg1_Scn10 at 00:44:57:13, requested for 00:44:57:09
 -- Starting scene Seg1_Scn11 at 00:49:57:13, requested for 00:49:57:00
 -- Starting scene Seg1_Scn12 at 00:54:56:28, requested for 00:54:56:21
 -- Starting scene Seg1_Scn13 at 00:59:56:13, requested for 00:59:56:12
 -- Starting scene Seg1_Scn14 at 01:04:56:13, requested for 01:04:56:03
 -- P-STD buffer underflow by 73999 bytes at 356418329, sector 2007740.
 -- Multiplex operation failed, probably caused by excessive bitrate.
 Dyn. allocated segment resources --> RELEASED
 --> 1 segments
 Dyn. allocated BmArg resources --> RELEASED
 --> 29 BmArg structures
 Local Stack memory --> RELEASED
 File i/o structures --> DEALLOCATED
	Is this source directly from your capture process?
 At first glance it looks like the source video is DVD compliant. The program passes the video as-is and re-encodes the audio to ac3.
 When it gets to the authoring stage, it gets about an hour in and balks at the bitrate.
 The average bitrate is OK, but there must have been a peak at that point that it didn't like.
 You could force the program to re-encode the video, or recapture at a slightly lower bitrate
 Here's the error:
  don't know what to do [VHS to MPG conversions need some work]By catsmeow in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2017, 03:04
  VHS Digitizing - Newbie QuestionsBy chilly_willy1 in forum Capturing and VCRReplies: 5Last Post: 19th Nov 2016, 11:44
  Newbie wanting help to convert VHS to DVD (copyright)By silky951 in forum Newbie / General discussionsReplies: 16Last Post: 20th Jun 2015, 11:50
  VHS to digital - Newbie HELPBy ewhit13 in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2014, 00:47
  Newbie to Honestech VHS to DVD 5.0 DeluxBy lucienalta in forum Capturing and VCRReplies: 12Last Post: 13th Apr 2013, 20:02
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
