Hi,
I am creating Home movies from DV format to XVCD currently , but would like to keep the highest quality version available with minimum space so that I can create DVD's out of the same movies when the prices come down on the burners . Here are my questions...
1) SHould I just convert all the movies to DVD format MPG? I back up everything to CD so that would limit me to about 15 minutes per CD correct? Is there a way to make the files smaller so that they will still play in my DVD player?
2) Should I/Can I convert them to Divx. If so how can I do this?
Thanks For Your Help
Bruce
Both MPEG and DivX are lossy formats. If you want to "keep the highest quality version available with minimum space so that I can create DVD's out of the same movies when the prices come down on the burners", store it as DV tape.
If you can live with little quality loss, check this topic
http://forum.vcdhelp.com/viewtopic.php?t=87063
or store it as miniDVD. Then you have to merge and reauthor later. -
Thanks,
I think I will go with storing it back onto the min dv. Though I am interested in the miniDVD you talked about. Where can I find information on that format?
Bruce -
Mini DVD has the same structure as DVD but burnt to CD. Hence you can fit about 15-25 min on one CD. Only few standalone players are able to play it. Check the "how to author" section.
BD backup file storage: which format? H.264, .mkv, .m2ts,
By jlm86 in forum Blu-ray RippingReplies: 6Last Post: 21st Feb 2011, 14:27 -
Long term storage format.
By DaveQB in forum RestorationReplies: 1Last Post: 23rd Oct 2009, 06:37 -
Best lossless format for storage/future editing for Hi8
By jkryan in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2009, 22:33 -
Best format for storage
By trikcard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Apr 2008, 09:18 -
Pls suggest compact Video format for episodic storage on DVD-R with menu
By Firewire60 in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 03:37
