Hey, guys.
I'm facing a little problem in the encode of my anime. My source is a Blu-ray disk.
Media-info:
I'm using the MeGUI, and I realized that the video gets weird in the preview and the encode finished.Code:General ID : 0 (0x0) Complete name : R:\Encode\HC Encode\00008.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 22.0 GiB Duration : 1 h 12 min Overall bit rate mode : Variable Overall bit rate : 43.3 Mb/s Maximum Overall bit rate : 48.0 Mb/s Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 27 Duration : 1 h 12 min Bit rate mode : Variable Bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : MBAFF Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.643 Stream size : 20.3 GiB (92%) Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : PCM Format settings : Big / Signed Muxing mode : Blu-ray Codec ID : 128 Duration : 1 h 12 min Bit rate mode : Constant Bit rate : 1 536 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Bit depth : 16 bits Stream size : 797 MiB (4%)
My script:
And this is the result in some parts of the video:Code:LoadPlugin("R:\Encode\MeGUI\tools\lsmash\LSMASHSource.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\masktools2.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\dither.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\avstp.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\Decomb.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\TIVTC.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\nnedi3.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\eedi3.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\RgTools.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\masktools2.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\yadifmod2.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\TDeint.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\GRunT.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\TMM2.dll") LoadPlugin("R:\Encode\MeGUI\tools\avisynth_plugin\EEDI2.dll") import("R:\Encode\MeGUI\tools\avs\plugins\FMDF.avsi") import("R:\Encode\MeGUI\tools\avs\plugins\dither.avsi") import("R:\Encode\MeGUI\tools\avs\plugins\Srestore.avsi") import("R:\Encode\MeGUI\tools\avs\plugins\AnimeIVTC.avsi") import("R:\Encode\MeGUI\tools\avs\plugins\sanimebob.avsi") import("R:\Encode\MeGUI\tools\avs\plugins\SMDegrain v.3.1.2d.avsi") LWLibavVideoSource("00008.m2ts") spline36resize(1280,720) TDecimate(mode=1) __film = last __t0 = __film.trim(0, 34792) __t0
Any tips on how I can fix this? Thanks.
Isn't that interlaced? 1920x1080 @29.97 fps for BluRay is required to be either interlaced, or telecined and encoded as interlaced.
https://www.videohelp.com/hd#tech- My sister Ann's brother -
You need to inverse telecine or deinterlace before resizing. Or use an interlace aware resizer. You probably want something like:
Code:LWLibavVideoSource("00008.m2ts") TFM() TDecimate() spline36resize(1280,720) trim(0, 34792)
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 07:32 -
Avisynth - Anime Blu-ray with downscale fails
By Ninelpienel in forum EditingReplies: 15Last Post: 26th Aug 2015, 17:06 -
Why the saturation boost and level expand on hd remaster old anime blu-ray?
By llansing in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2014, 17:56 -
multiAVCHD Blu Ray content on DVD-R problems in Blu Ray player
By erek in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Aug 2013, 22:25 -
Original anime DVD/Blu-ray
By bluergost in forum Blu-ray RippingReplies: 1Last Post: 13th Mar 2013, 02:25
