Ok, sorry if this is a rehash but if I'm capturing shows from a source (satellite receiver) and I want to make the output similar to what I would see if I had the show on a DVD, here's what I've calculated.
Let's take a movie on a DVD (dual layer NON blue-ray) for example. That's roughly 2 hours or so for 7-8 Gb of data. So that works out to roughly 7.7 to 8.8 Mb/s. Capturing at that rate should make my output similar to a DVD.
Most movies are done at 30fps. It's kind of funny how satellite transmissions send a signal out at 60fps. If it's only 30fps to begin with isn't upscaling it to 60fps overkill?
Results 1 to 1 of 1
Best 720p capture rate
By Christopher2222 in forum Capturing and VCRReplies: 33Last Post: 13th Feb 2018, 17:36 -
What does a constant 30.302 fps frame rate mean?
By Aquinax in forum Video ConversionReplies: 11Last Post: 5th Apr 2016, 14:45 -
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30 -
frame rate reduction of 29.970 fps to 23.976 fps in megui
By yohanfed in forum Video ConversionReplies: 2Last Post: 28th Jun 2014, 20:15 -
Increasing fps rate when re-encoding video possible? Prevent stuttering
By pxstein in forum Newbie / General discussionsReplies: 4Last Post: 26th Jun 2014, 11:46
