I've got an animated DVD source where the video was digitally created and stored at 60i on the disc. It IS interlaced as there are many scenes with 60i fast moving effects, but being 2D animation is largely progressive in appearance. I'm using DGIndex and MPEG2SOURCE to frameserve to AVISynth using MeGUI. Both the video preview window and the final encode have an exaggerated stair step effect that is most pronounced on diagonals and anything red. After much reading my understanding is that this is caused by the general low resolution of chroma in the first place, halving it again due to being interlaced, and perhaps coupled with the chroma upsampling error.
I cannot find a hard and fast solution to this. My approach is to use the following code to smooth the chroma and then apply a bit of resharpening. But is there a better way?
SAMPLE HERECode:mpeg2source("clip.d2v") TFM() KNLMeansCL() clean=last maa2mod(chroma=true, aac=32).awarpsharp2(depth=2) mergechroma(clean, last)
As in any situation where cadence may be an issue, post a
20 seconds or so clip from the source -
For this kind of telecined clip use tdecimate to reduce to 23.976 fps
video=mpeg2source("C:\your_path\Sample2.demuxed.d2 v")
video=video.tfm().tdecimate()
return video -
Strong chroma deblocking:
Code:#progressive frames luma=last Deblock_QED(quant1=30, quant2=30) Santiag() aWarpSharp(depth=10) MergeChroma(luma,last)
The filters TFM and TDecimate are provided by the TIVTC plugin. The rest ... even more plugins (*.dll) and possibly also import scripts (*.avsi).
interlaced or progressive scan
By devdev in forum Video ConversionReplies: 8Last Post: 11th Nov 2017, 12:09 -
Interlaced Content to Progressive
By TE16 in forum Video ConversionReplies: 2Last Post: 14th Jan 2017, 16:38 -
interlaced or progressive: where are the flags?
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 30th Mar 2016, 11:23 -
Progressive vs Interlaced questions
By Banner58 in forum Newbie / General discussionsReplies: 11Last Post: 6th May 2013, 11:49 -
About the progressive to interlaced
By 861stvideoedit in forum EditingReplies: 1Last Post: 11th Apr 2013, 03:18
