I need to rip this live stream
http://www.paramountchannel.it/tv/diretta
but i cant find how to rip it. please someone tell me a valid method. thank you.
Results 1 to 17 of 17
Use youtube-dl
Code:youtube-dl http://www.raiplay.it/video/2018/02/Cerimonia-daposapertura-del-09022018-55f638c4-29fa-48e2-8073-eea4d8568f3b.html
Start your browser's Developer Tools (F12). Load the page. Look through network traffic for an m3u8 URL. Use that in youtube-dl.
Sorry but youtube-dl dont work give me an error.
if u can try to start ripping with it...... -
The URL you get may be different than the one I get. I successfully downloaded a video using the command line I gave.
One problem with youtube-dl downloading live streams is there's no end to the stream. You have to use CTRL+C or CTRL+Break to terminate the download. And you have to remove ".part" from the end of the filename. This sometimes gives you a file that doesn't play.Last edited by jagabo; 14th Feb 2018 at 12:43.
I have use your command line
youtube-dl http://viacomitalytest-lh.akamaihd.net/i/sbshdlive_1@195657/master.m3u8
but like i have tell before give an error and dont rip nothing
now why you dont't have the same error?
i have notice that youtube-dl use ffmpeg and is ffmpeg that give me the error
look the image
https://imgur.com/a/1oGRCLast edited by Fathom; 14th Feb 2018 at 14:11.
youtube-dl gives a bunch of error messages at first but it continues to download the video. Try specifying getting the list of available videos and then specifying which to download:
get list:
download specific video:Code:youtube-dl -F http://viacomitalytest-lh.akamaihd.net/i/sbshdlive_1@195657/master.m3u8
Code:youtube-dl -f 1264-0 http://viacomitalytest-lh.akamaihd.net/i/sbshdlive_1@195657/master.m3u8
Sorry but dont change nothing the error is the same
i used this command line you tell me "youtube-dl -f 1264-0 http://viacomitalytest-lh.akamaihd.net/i/sbshdlive_1@195657/master.m3u8"
and stop to rip. dont continued to download video, it dont start to download -
Do you have a recent version of youtube-dl? I was using one from January this morning. Then later I updated to one from February to see if I could duplicate your problem.
Did you use your browser's developer tools to verify you get the same link when playing the video? And you are in Italy or using a VPN there?
I don't know what else to tell you. -
i have resolved with another tool, livestreamer, i used this command line and i can rip
the stream in mp4, but is not playlable so i have to fix it. I try with avidemux without encoding and seem to work but not perfectly, the first 2minutes of video is a black screen then i can see it.
livestreamer "hlsvariant://http://viacomitalytest-lh.akamaihd.net/i/sbshdlive_1@195657/master.m3u8" best -o pr.mp4Last edited by Fathom; 16th Feb 2018 at 05:18.
How would I download this stream?
By AshleyQuick in forum Video Streaming DownloadingReplies: 7Last Post: 3rd May 2017, 20:54 -
stream download
By vidblue in forum Video Streaming DownloadingReplies: 2Last Post: 6th Sep 2016, 17:48 -
Help me with Stream download please
By darkramza in forum Video Streaming DownloadingReplies: 4Last Post: 28th Jul 2014, 16:34 -
Need help for download a stream ..?
By zoom1991 in forum Video Streaming DownloadingReplies: 11Last Post: 4th Apr 2014, 18:30 -
Stream Download
By Rulez in forum Video Streaming DownloadingReplies: 1Last Post: 21st Nov 2013, 16:36
