Vidcoder/Handbrake encodes too dark/washed out? Is there a fixed to this?
The left is the preview encode from vidcoder. The right is the image from my DVD VOB file playing in VLC media player. I've already reset the settings in VLC back to default and the following is what I get. I've read about this issue somewhere on the internet before about handbrake but I never came across a reasoning as to why or how to go about fixing this.
Any solution?
EDIT: Re-tested again, and I'll probably have to do an A B side by side comparison when the actual encode finishes (haven't started). But I think Vidcoder's own preview screen is causing the colors to look washed out. When I used "open in system player" option to play the same preview in VLC media player, the colors looks vibrant just like the original VOB source.
I'll try to update this thread with the same screen capture when I get around to encoding my beauty and the beast DVD.
YUV full range vs limited range issue. If you're upscaling you should convert to rec.709 colors and flag it as such.
It'll be a playback issue. Even if it looks washed out in the preview it won't effect how it's encoded.
I'm not sure if Vidcoder's preview would be effected by the video card settings, but have a look for a video setting such as "full range" or "limited range" and make sure it's set to full range. Something like this:
http://avisynth.nl/images/Nvidia_control_panel.jpg
How accurate are preview encodes with Vidcoder, Handbrake, etc?
By strawberryshortcake in forum Newbie / General discussionsReplies: 0Last Post: 13th Feb 2018, 21:24 -
Will Handbrake and VidCoder ever get NVenc support?
By bizzybody in forum Video ConversionReplies: 1Last Post: 5th Feb 2018, 02:55 -
Encoding a DVD while gaming? Anything better than Handbrake/VidCoder?
By yuppicide0138 in forum DVD RippingReplies: 10Last Post: 10th Feb 2016, 18:33 -
Detelecine with Vidcoder/Handbrake
By Lowlander in forum DVD RippingReplies: 3Last Post: 29th Apr 2015, 10:26 -
VidCoder & HandBrake Q
By elling in forum Video ConversionReplies: 2Last Post: 4th Mar 2015, 15:51
