Aside from vertical blurring, what else can remove adaptive deinterlace jaggies?
Drop-frame is/was a bit easier, simple anti-aliasing needed. This specific dumb "smart" deinterlace method, not so much.
Use a better deinterlacer? You've provided no sample, nor what script/deinterlacer you're using or have tried.
And sometimes the aliasing is in the source, and might remain after being deinterlaced, irrespective of the deinterlacer you use.
What to use to fix it after the fact? Maybe QTGMC in its progressive mode. But it's often too destructive of detail to use it. Or try one of the many anti-aliasing filyers. -
I wasn't the one who use the bad deinterlacer, and it was done more than a decade ago. Original tapes long ago tossed. So a moot aspect at this point. The damage is already done.
Nope, not in the source.
Already tried QTGMC. No help on an adaptive.
What "many anti-aliasing filyers" (fillers?) do you refer to?
Not able to share sample, and this is mostly meant as brainstorming for possible methods anyway. I have my methods, and have for many years. But I'm always learning, see what's new, seeing what I may have missed in the past.Want my help? Ask here! (not via PM!)
Sometimes it helps to SeparateFields(), SelecteEven() (or odd), and nned3(dh=true). Or blend both even and odd (with appropriate line shift).
Oops, sorry, filters. I don't use them as I don't work on anime these days and don't have to fix badly deinterlaced sources. However, take your pick:
http://avisynth.nl/index.php/External_filters#Anti-aliasing
Maybe try DAA or Santiag. -
Will look into it. Thanks.
Already tried santiag(), and it works worse that AAA(). I could never get DAA() to work right, and doubt it's much different anyway.
This isn't toons.
And I'm not really an anime fan, like maybe 10-20 at most (mostly Macross). Prefer dubs; I have books if I want to read.
I'm thinking vertical blur is still our main options, even with AA.Want my help? Ask here! (not via PM!)
I did mention both anime and 'badly deinterlaced sources'. It's with anime that one reads about the most need for anti-aliasing filters. In its doc, QTGMC has examples of settings for cleaning up badly deinterlaced sources:
Progressive Input
Key Points: Can remove horizontal shimmering effects from progressive sources. Experiment with InputType=1, 2 or 3 for best results. FPS will not be doubled.
InputType=2,3 are designed for badly deinterlaced material with considerable horizontal artefacts.
QTGMC( Preset="Slower", InputType=2, ProgSADMask=12.0 ) # Process progressive source with major artefacts, slightly favoring detail over repairs
x265 Adaptive GOP
By Rosh in forum Video ConversionReplies: 0Last Post: 21st Aug 2015, 15:22 -
Avisynth script help jaggies
By Stevie Hyper in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2014, 17:43 -
What can be done about jaggies?
By brassplyer in forum RestorationReplies: 9Last Post: 19th Feb 2014, 22:50 -
Seems like I have to settle for either jaggies OR interlacing combing?!
By jonfopp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 11th Jan 2014, 11:09 -
Satellite F1 SD vs HD (upscaled from SD) - horrible jaggies
By VideoFanatic in forum RestorationReplies: 1Last Post: 30th Dec 2013, 23:41
