Hello, dear all.
I like to test programs. Subtitling programs also, as I make subtitles from some videos when needed.
Concerning about VisualSubSync, do you know how to make the video bar appears not on the side of the audio bar, but on the side of the text bar?
1) Audio Bar + Video Bar Together - On the same side ( default ):
[Attachment 44676 - Click to enlarge]
2) Audio Bar Alone at the Top of the Program + Video Bar on the Side by Text Bar:
[Attachment 44677 - Click to enlarge]
[Attachment 44678 - Click to enlarge]
If you have some tips to do it it will be nice to hear!
Thanks.
Best regards.
devil (johner)
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
First of all, thank you because I didn't know that videohelp had a section dedicated to Visualsubsync Enhanced and it's an honor as it is an absolute reference point.
Your question is quite simple, the video can be detached from the interface
normally is on the right side of the audio preview section
but you can detach it using the option in view menů
and move it where you want
@ red5goahead
Hi! Thanks for your reply!
Very easy. And helps if I let audio bar at the top alone. More room for timing job. Specially if PC monitor is large / lengthy.
Do you know if VisualSubSync has some plugins available nowadays? I mean, some "tools" that can improve / extend even more the power of VisualSubSync?
I could find some link:
---> https://www.visualsubsync.org/links
For those who want to create karaoke subtitles ( or even anime ASS/ SSA sophisticated subtitles ) using VisualSubSync can you point some nice tutorial? I mean: we can do karaoke / anime subtitles using VSS, yes?
And again: many thanks for your help!
I liked a lot the enhanced version! Such nice program should always be improved and updated!
Best regards.
devil (johner)Last edited by devilcoelhodog; 15th Feb 2018 at 00:41.
MKVToolNix progress bar
By Vigoo in forum EditingReplies: 2Last Post: 20th Aug 2017, 18:48 -
Best Audio for Bar Mitzvah?
By nmiwrld in forum AudioReplies: 3Last Post: 3rd May 2017, 13:20 -
im looking for a tool to sync audio with a slidable bar
By vectoravtech in forum Newbie / General discussionsReplies: 15Last Post: 10th Feb 2016, 07:05 -
how can i crop a video without the black bar?
By rama in forum EditingReplies: 27Last Post: 15th Jun 2015, 14:10 -
how to get rid of the black bar ?
By ahmadss in forum Blu-ray RippingReplies: 22Last Post: 9th Dec 2014, 14:43
