I've got 1000's of videos that need to be checked to make sure that English is the default audio track and foreign language audio tracks removed. This normally isn't an issue because I found a script that does just that, however, for audio tracks that are not labeled I have to check them manually. Part of the problem is I'm not sure which video files do not have properly labeled audio tracks and my second issue is how do I quickly process all these videos manually. I have been adding them to MKVToolnix GUI and removing the foreign language track, but this is super tedious as it requires me to load the video and figure out which track is English. Is there a faster way? Perhaps there is a "file explorer" for MKV videos that will show me how many audio tracks there are and the language for multiple files at once?
Below is the vbs script I use for isolating English audio when properly labeled, I found it somewhere on this forum.
Code:Option Explicit Dim strInputFileName Dim strBaseFileNameNoExt Dim strTempFileName Dim strOutputFileName Dim MediaObjectList Dim objArgs Dim objFSo Dim objShell Dim strTitle Dim strTitleChunks Dim TrackSelection Set objArgs = WScript.Arguments Set objFSo = CreateObject("Scripting.FileSystemObject") Set objShell = CreateObject("WScript.Shell") For Each strInputFileName in objArgs Call GetBaseFileNameNoExt ' FQ FileName without extension Call ParseTitle ' Filename without Path or Extension Call GetTrackInfo ' Identify Desired Tracks Call RenameInputFile ' Rename Input to .tmp in case input is already .mkv Call SetOutputFileName ' FQ FileName with MKV extension Call RemuxFile ' Remux 'Call DeleteSource ' Delete Source if Output Created Next Sub GetBaseFileNameNoExt strBaseFileNameNoExt = Trim(Left(strInputFileName,InstrRev(strInputFileNa me,".")-1)) End Sub 'GetBaseFileNameNoExt Sub RenameInputFile strTempFileName = strInputFileName & ".tmp" objFSO.MoveFile strInputFileName ,strTempFileName End Sub 'RenameInputFile Sub SetOutputFileName strOutputFileName = strBaseFileNameNoExt & ".mkv" End Sub 'SetOutputFileName Sub ParseTitle strTitleChunks = Split(strBaseFileNameNoExt,"\") strTitle = strTitleChunks(UBound(strTitleChunks)) If Instr(strTitle,"[") Then strTitle = Trim(Left(strTitle,InstrRev(strTitle,"[")-1)) End Sub 'ParseTitle Sub GetTrackInfo Dim CommandLine Dim MediaObject Dim MediaObjects Dim Track Dim VideoTracks Dim AudioTracks Dim SubTracks Dim TrackOrder TrackSelection = "" CommandLine = """" & GetMKVExecutable & """ " CommandLine = CommandLine & "-i -F verbose-text " CommandLine = CommandLine & """" & strInputFileName & """ " Set MediaObjectList = objShell.Exec(CommandLine) MediaObjects = Split(MediaObjectList.StdOut.ReadAll, vbCrLf) For Each MediaObject In MediaObjects Select Case Left(MediaObject,8) Case "Track ID" Track = Split(MediaObject," ",5) Select Case Track(3) Case "video" TrackSelection = TrackSelection & "--track-name """ & Track(2) & strTitle & """ " VideoTracks = VideoTracks & " " & Replace(Track(2),":","") Case "audio" If Instr(Track(4),"language:eng") Then TrackSelection = TrackSelection & "--track-name """ & Track(2) & strTitle & """ " AudioTracks = AudioTracks & " " & Replace(Track(2),":","") ElseIf Instr(Track(4),"language") = 0 Then TrackSelection = TrackSelection & "--track-name """ & Track(2) & strTitle & """ " AudioTracks = AudioTracks & " " & Replace(Track(2),":","") End If Case "subtitles" If Instr(Track(4),"language:eng") Then TrackSelection = TrackSelection & "--track-name """ & Track(2) & strTitle & """ " SubTracks = SubTracks & " " & Replace(Track(2),":","") ElseIf Instr(Track(4),"language") = 0 Then TrackSelection = TrackSelection & "--track-name """ & Track(2) & strTitle & """ " SubTracks = SubTracks & " " & Replace(Track(2),":","") End If Case Else 'msgbox(Track(3)) 'Not Processing other values at this time End Select Case Else 'Not Processing other values at this time End Select Next If Len(SubTracks) > 0 Then TrackSelection = "-s " & Replace(Trim(SubTracks)," ",",") & " " & TrackSelection TrackOrder = Replace(RTrim(SubTracks)," "," 0:") Else TrackSelection = "-S " & TrackSelection End If If Len(AudioTracks) > 0 Then TrackSelection = "-a " & Replace(Trim(AudioTracks)," ",",") & " " & TrackSelection TrackOrder = Replace(RTrim(AudioTracks)," "," 0:") & TrackOrder End If If Len(VideoTracks) > 0 Then TrackSelection = "-d " & Replace(Trim(VideoTracks)," ",",") & " " & TrackSelection TrackOrder = Replace(RTrim(VideoTracks)," "," 0:") & TrackOrder End If TrackOrder = "--track-order " & Replace(Trim(TrackOrder)," ",",") TrackSelection = TrackSelection & TrackOrder & " " End Sub 'GetTrackInfo Sub RemuxFile Dim CommandLine CommandLine = """" & GetMKVExecutable & """ " CommandLine = CommandLine & "--title """ & strTitle & """ --no-global-tags --no-track-tags " CommandLine = CommandLine & TrackSelection CommandLine = CommandLine & "-o """ & strOutputFileName & """ " CommandLine = CommandLine & """" & strTempFileName & """ " If Instr(TrackSelection,"-d ") = 0 Then Exit Sub 'Video Track Not Identified If Instr(TrackSelection,"-a ") = 0 Then Exit Sub 'Audio Track Not Identified objShell.Run CommandLine,7,True End Sub 'RemuxFile Sub DeleteSource If ValidFile(strOutputFileName) Then objFSO.DeleteFile strTempFileName End Sub 'DeleteSource Function GetMKVExecutable If ValidFile("C:\Program Files\MKVToolNix\mkvmerge.exe") Then GetMKVExecutable = "C:\Program Files\MKVToolNix\mkvmerge.exe" ElseIf ValidFile("C:\Program Files (x86)\MKVToolNix\mkvmerge.exe") Then GetMKVExecutable = "C:\Program Files (x86)\MKVToolNix\mkvmerge.exe" Else GetMKVExecutable = NULL msgbox("*** MKV Tools NOT Detected ***") End If End Function 'GetMKVExecutable Function ValidFile(FileName) Dim Outfile ValidFile = False If objFSO.FileExists(FileName) Then Set Outfile = objFSO.GetFile(FileName) If Outfile.size > 100 Then ValidFile = True End If End If End Function 'ValidFile
	Hi.
 This post was edited. BIG TIME.
 Edited again. (Bedtime for me.)
 Left out the '-acodec copy' parameter.
 Please read it again. The batch file has changed.
 I've got no videos to test with. I tested it on MKVs with only English subtitles.
 Save the following script - test1.cmd
 Put it in a folder with a bunch of MKV videos.
 You also need ffmpeg.exe
 Run the batch file.
 Should catch most videos. If the first stream is NOT the video there may be problems.Code:@echo off if not exist NEW\*.* md NEW if exist temp\*.* (del /q temp\*.*) else md temp for %%a in ("*.mkv") do call :Process "%%a" goto :end :Process :: Set the first stream, normally the video, to English. (In case it's not English.) ffmpeg -i "%~1" -vcodec copy -acodec copy -metadata:s:0 language=eng -y "temp\%~1" :: Copy the English streams (video+audio) to a new video. ffmpeg -i "temp\%~1" -vcodec copy -acodec copy -map 0:m:language:eng -y "NEW\%~1" goto :eof :end rd /s /q temp
 If a stream, video or audio, has no language defined, well.....
 Cheers.
 Edit:
 A slightly different version is posted here.
 https://forum.videohelp.com/threads/377677-Video-batch-files/page3
 Also a second batch file to find MKVs with NO English tag defined in the METADATA.
 It's a thread I started some time ago. Didn't want to be accused of duplicate posting.  Last edited by pcspeak; 15th Feb 2018 at 17:11.
  BULK remove non-English tracks from MKV container?By soulhunter123 in forum AudioReplies: 44Last Post: 28th Dec 2018, 13:30
  Removing audio tracks from mkvBy MaRa-23 in forum Video ConversionReplies: 39Last Post: 20th Oct 2015, 05:25
  Any way to see delay applied to audio tracks in an MKV ?By cpaqf1 in forum Video ConversionReplies: 3Last Post: 22nd Apr 2014, 16:13
  How to remove audio tracks from many MKV files?By santaxl in forum Video ConversionReplies: 12Last Post: 21st Jan 2014, 05:04
  Can't select audio tracks MKV LG BP33By hecramsey in forum DVD & Blu-ray PlayersReplies: 2Last Post: 26th Dec 2013, 18:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
