Hi gys, I currently encoding from HD to DVD and trying between two programs (I need it), but I just dont know what result is better, so, I so in several sites some posted images comparison and that is just that I need, but I dont know how to do that?
I mean, an example, I have two DVD movies that was previously encoding but I so need to compare that movies taking some picture from them so IŽll can see the result from both
Thank you in advance!!
Alt+PrintScreen and paste into MS Paint? If I'm only looking at an individual frame then that's how I do all of my quick comparisons. Then it's just ctrl+z and ctrl+y to flip back and forth.
Avisynth (using with AvsPmode) or Vapoursynth and compare particular video frames directly
Open the videos using two instances of VirtualDub FilterMod. Step through them and compare.
Using any image editor with layers, put image B on top of image A and toggle B's layer off and on. Or (for a different, more technical comparison) set B's merge mode to "difference."
Using AviSynth, use Interleave(A, B). This is only useful in frame jog mode! Or use Subtract(A, B) -
And that's the *best* feature of avspmod. Tabs! .
You can load different versions in different tabs, and the number keys to toggle. It's automatically aligned if they are the same video (same dimensions, framecount) , and you can seek to another frame (e.g. frame 3753), and all tab instances are aligned on that same frame so you can toggle between them easily. If you want to save a screenshot, you can do that directly from avspmod too -
When I'm doing serious comparisons of encoding settings I use three videos, the original and the two encoded videos, interleaved as original, encoded 1, encoded 2, original. This makes it easy to switch back and forth directly between the original and encoded 1, encoded 1 and encoded 2, and encoded 2 and the original.
Code:original = WhateverSource("original.ext") encoded1 = WhateverSource("encoded1.ext") encoded2 = WhateverSource("encoded2.ext") Interleave (original, encoded1, encoded2, original)
And, of course, not all issues show up when examining still frames like this; some problems need to be seen at normal playback speed. You can use StackHorizontal() or StackVertical() to play back multiple files simultaneously.
Code:original = WhateverSource("original.ext") encoded1 = WhateverSource("encoded1.ext") encoded2 = WhateverSource("encoded2.ext") StackHorizontal(original, encoded1, encoded2)
batch that compare filename in 2 folder
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 3rd Oct 2017, 04:58 -
How to compare audio/video tracks?
By vishnu-krishna in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2015, 04:06 -
Software to compare similar subtitles
By AtotehZ in forum SubtitleReplies: 6Last Post: 26th Mar 2015, 08:03 -
How Can I Visually Compare Two Encodes?
By Pilotwings_64 in forum Video ConversionReplies: 10Last Post: 4th Jun 2014, 07:06 -
why is VLC so unstable compare to others?
By muffinman123 in forum Software PlayingReplies: 14Last Post: 22nd Jul 2013, 13:13
