What Codec and settings do you use to capture your aivs? Please Post them I want to find the best one! Thanks for the help
TitaniumDragon :P
Wow, that was big, bold and colourful!
I use the following:
Full frame
UYUV
Huffyuv (best compression settings...as per the menu)
no noise reduction, no cropping, no filtering
44.1k audio, no compression
I think that is best...and I'm sure many will both agree and disagree! -
If you want to acheive the "best" results then use this guide
http://www.vcdhelp.com/mjpeg.htm
You should capture at your target horizontal resolution and at full vertical resolution. So if you want to make an NTSC VCD then you should capture your source video at 352x480 and then resize.
If you want to capture to MPEG for direct burning onto VCD (no re-encode necessary but quality suffers) then use this guide
http://www.vcdhelp.com/mpeg.htm
In this case you will have to capture at your target horizontal and vertical resolution (e.g. 352x288 for NTSC VCD) to avoid re-encoding
virtual dub não abre arquivos cokm codec xvid
By sandroguchilo in forum AudioReplies: 3Last Post: 14th Dec 2010, 17:43 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 16:12 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 13:08 -
Xvid Codec settings (1.2.2)
By glenpinn in forum Video ConversionReplies: 2Last Post: 21st Jun 2009, 11:29 -
AC3 codec/filter with virtual dub and TMPGEnc
By buzzsaw in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 18:47
