So for a long time I've been encoding bluray movies for a while and I usually don't get any problems. I use a combination of avisynth and MeGUI.
The codecs I've installed are ffdshow and haali media splitter.
Occasionally in my encodes the picture glitches, seems to be specifically with movies that are VC-1 but I can confirm that's not always the case. (I use FFVideoSource for VC-1 movies)
So I'm just wondering if there's anything else I should have installed that would ensure things go smoothly from here on.
Yes, ffmpeg VC-1 software decoder is bugged and ffdshow and ffvideosource are based on ffmpeg.
Today "no one" uses ffdshow or Haali anymore as their development stopped long time ago. You can stick to ffvideosource for H.264 Blu-Rays. For VC-1 you can use:- DGDecNV
- FRIMSource
- DirectShowSource() with LAV Video (in LAV Video do not deactivate WMV MFT decoder, or use DXVA2 copy-back or D3D11)
- DSS2() with LAV Video (in LAV Video do not deactivate WMV MFT decoder, or use DXVA2 or D3D11)
- DSS2mod (DSS2 with LAV inbuilt, I don't know if there are more recent versions but it's probably still good enough for VC-1 Blu-Ray)
DGDecNV might be the most stable option but it requires suitable Nvidia GPU and is not freeware ($15). -
Thanks for your response.
I tried FRIMSource but it just said "unknown codec". DSS2 ended up working though.
I did however run into another issue, mentioned here.
https://forum.videohelp.com/threads/387971-Problem-with-audio-video-sync -
Bump on the OP cus didn't really get an idea of what programs/applications to install
Are you trying to encode the main movie ? M2TS/vc-1 source? Use mkvtoolnix to make an mkv out of it
then use Lsmashsource in Avisynth, encode in any Avisynth capable host program - even
ffmpeg should be fine since the decoding is done in the .avs script
https://github.com/HolyWu/L-SMASH-Works/releasesLast edited by davexnet; 17th Jun 2021 at 19:26.
Wise advice needed on Bluray Encoding
By SimplyFred in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2017, 05:37 -
HEVC Hardware Decoding/Encoding
By jmdale1984 in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2015, 23:58 -
Queries on HEVC encoding and decoding errors
By ironurn in forum Video ConversionReplies: 1Last Post: 16th Jul 2015, 03:34 -
What is the minimum configuration of DVDFab needed to rip/decrypt BluRay?
By timg11 in forum Blu-ray RippingReplies: 3Last Post: 9th Aug 2014, 01:19 -
Can you fit multiple movies on bluray media?
By rz514 in forum Authoring (Blu-ray)Replies: 12Last Post: 28th Apr 2013, 00:29
