Hi,
can you help me choose new avatar, that should say that I'm chess enthusiast? I made several chess pieces for fun, but now trying to make complete chess set. I took few pieces as sample. I will be very grateful if you help me choose some that will more express my chess hobby, and get off this avatar I'm using now. (I hate him too).
I know, that you can hate them all, so please let me know which you hate less. It is biggest problem to hit everybodys taste (fancy, liking or tact).
Link to the picture 2 MB PNG
Thank you
Bernix
Results 1 to 14 of 14
Hi Redwudz,
thank you for your opinion. Chess board is leading now. People apparently don't like everything I made
There isn't too much to spoil on board
Will wait some time if somebody say something and will change avatar then. But don't think somebody will reply something
Thank you again!
Bernix -
Paintdotnet : took about 2 minutes (took about as long to upload it!!)
125x100Yes, no, maybe, I don't know, Can you repeat the question? -
Thank you, cornemuse!
Still will wait a bit. But it seems avatar will be red
Thank you again!
Bernix -
Hi, the problem with chess pieces is they may look that way for some people. All has base, then body and finally head. But probably related to Rorschach picture effect.
But thank you for take a part here!
Bernix -
Text formatting test: Probably sounds great, but a lot of wiring. The whole main idea is to have separate sounds from all sides and above.
I still use the 5.1 surround setup, but with two subwoofers, two front stereo, center channel, and two rear channels.
7.1 uses four rear surround speakers, along with the front stereo, the center speaker and the subwoofer.
https://www.dolby.com/us/en/guide/surround-sound-speaker-setup/7-1-setup.html
And with any surround setup, you have to consider your room size, speaker placement, seating placement, room accoustics and budget. And other things.Last edited by redwudz; 15th Jul 2019 at 20:37.
How is it with legality of Avatar?
By Bernix in forum Off topicReplies: 1Last Post: 5th Jan 2018, 20:19 -
Your Avatar: explainations requested
By cornemuse in forum Off topicReplies: 56Last Post: 8th Jun 2017, 14:22 -
Need advice ripping avatar and merging 2 parts into 1
By TopherBG2 in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2017, 23:48 -
Test. Where's my avatar?
By vorp in forum TestReplies: 39Last Post: 25th Jan 2014, 05:11 -
Avatar Extended Edition forced subtitles issue with RipBot264
By DrPreston in forum SubtitleReplies: 16Last Post: 24th May 2013, 16:51
