Hi,
i'm a linux user but i use gMKVExtractGUI with wine on my linux machine because there is no good mkv extract gui for linux (i only know mkv-extractor-qt5 and i don't like it). on linux i can create service menus that i can see when i right click in the file manager. when i want to open a file directly in a program i can do something like
where %F is the file i want to open in program. off course some linux tools don't support that, for example makemkv, and i have to open the program and select the file with "open file". can i directly open a mkv file in gMKVextractGUI in this way? off course also on windows you can create something like service menus (i don't know the name on windows) and maybe there is a solution to do that with gMKVExtractGUI?Code:program %F
To me mkv extractor qt5 works fine with Linux.
You can also try Inviska MKV Extract, but be aware that it doesn't work yet with version 20 of mkvtoolnix. -
first i tried
Code:wine /pad/to/program.exe %F
Code:sh -c "env WINEPREFIX='/home/valit/.wine' wine '/path/to/gMKVExtractGUI/gMKVExtractGUI.exe'" %F
To me mkv extractor qt5 works fine with Linux. -
yes it works, but the output files always have the same name. when i demux 2 or more files in the same folder, the demuxed files overwrite each other. all other (windows) demuxen i know include the input file name in the output file name.
mkv extractor qt5 can do this too, open the files one by one, right click in the sourcelist window and select all, go to file en select a different output folderLast edited by jan5678; 11th Feb 2018 at 08:57.
no. batch is when i import an file, select the streams i want to demux and send that to a batch list. then i do the same with the next file and send it also to the batch list. after that i start the batch.
i can't find something like this in mkvextractor-qt5.
what i mean is that the output names are always the same
2_audio_English.aac -
Oke i understand, maybe you should report this behavior to the maker of mkv extract qt5? i think it's a design flaw
Did you tried it with inviska?, i can't test it because i have mkvtoolnix v20 installed. -
not at the moment. i also use mkvtoolnix 20. maybe i'll test it on my notebook, its a little bit out of date and the mkvtoolnix version should be older.
Matroska text file attachment
By Bigo2 in forum Software PlayingReplies: 10Last Post: 12th Jul 2022, 09:30 -
How to AHD Subtitles Maker Open FLV and MP4 Video Files Directly?
By devilcoelhodog in forum SubtitleReplies: 2Last Post: 22nd Nov 2015, 10:00 -
FFMPEG: can open a video file directly on ftp?
By marcorocchini in forum Newbie / General discussionsReplies: 6Last Post: 15th Feb 2015, 03:55 -
Authoring a DVD using a Matroska File
By efiste2 in forum Authoring (DVD)Replies: 1Last Post: 21st Aug 2014, 09:38 -
Can we transpose directly an ac3 file ?
By Patapin in forum AudioReplies: 2Last Post: 29th Oct 2013, 03:49
