  1. Why, when I processed a video from any of the programs (DVDPatcher, ReStream, MPGPatcher), just changing the AR and resolution, my frames become blocky? No coding was done, just changed 3 values ​​- Aspect Ratio, Height and Width, but for some reason such a problem. I'm waiting for helpImage
    [Attachment 44656 - Click to enlarge]
    [Attachment 44657 - Click to enlarge]
    Mar 2008
    Some kind of decoding error ? Is this in the preview?
  3. Originally Posted by davexnet View Post
    Yes. How to remove? In one player all frames white. I can share video before and after
    Mar 2008
    Post a mediainfo (text view) of your source file
  5. Originally Posted by davexnet View Post
    General
    Complete name : D:\VirtualDub\video.mpg
    Format : MPEG-PS
    File size : 56.6 MiB
    Duration : 1 min 8 s
    Overall bit rate : 6 946 kb/s
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format settings, picture structure : Frame
    Bit rate mode : Variable
    Bit rate : 5 719 kb/s
    Maximum bit rate : 8 000 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.552
    Time code of first frame : 01:21:43:15
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 46.5 MiB (82%)
    Audio #1
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Muxing mode : DVD-Video
    Bit rate mode : Constant
    Bit rate : 448 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Delay relative to video : -163 ms
    Stream size : 3.65 MiB (6%)
    Service kind : Complete Main
    Audio #2
    ID : 189 (0xBD)-129 (0x81)
    Format : AC-3
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Bit depth : 16 bits
    Delay relative to video : -99 ms
    Stream size : 1.56 MiB (3%)
    Audio #3
    ID : 189 (0xBD)-130 (0x82)
    Format : AC-3
    Bit rate : 448 kb/s
    Bit depth : 16 bits
    Delay relative to video : -195 ms
    Menu
  6. Originally Posted by davexnet View Post
    Please help, without encoding, I edit flags in all frames.
  7. Originally Posted by Megafox View Post
    General
    Format : MPEG-PS
    Video
    Format : MPEG Video
    Width : 720 pixels
    Height : 480 pixels
    Standard : NTSC
    Color space : YUV
    Bit depth : 8 bits
    Audio #1
    Format : AC-3
    Bit rate : 448 kb/s
    Bit depth : 16 bits
    Audio #2
    Format : AC-3
    Bit rate : 192 kb/s
    Bit depth : 16 bits
    Audio #3
    Format : AC-3
    Bit rate : 448 kb/s
    Bit depth : 16 bits
    Menu
    You know, what this? Or no
