Results 1 to 15 of 15
    Jul 2003
    Turkey
    Hello everybody,
    I want to learn something about these products and WinTV 8 software. If you use Hauppauge HD PVR 2 or Hauppauge Colossus 2, you can help me much.
    Do you suggest these products for real time capturing?
    I know these cards are for gamers. But I want to use them for capturing from digital or analog video sources in mp4 format. What I want to learn is if these products capture in mp4 format directly without convertion from TS or MPG formats. When I stop capture, I want an mp4 file to be ready at once without having to wait for re-encoding.
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Maybe ask Christopher2222, who started this thread.
    https://forum.videohelp.com/threads/387718-Best-720p-capture-rate
    What device do you have that needs MP4s? As often times it is going to need to be able to deinterlace 1080i content that you record, should you want to play these recordings raw.
    Jul 2003
    Turkey
    I will change the thread after this reply.
    We have HD tape camcorder, VCRs and, analog camcorders like Digital8, Hi8, Mini DV. We used Hauppauge PVR-250 before for mpeg-2 capture. Now, We want to record from these analog sources to mp4 format directly. We know analog sources' quality is not more than 720x576 but people prefer mp4 format in order to play them via tv's usb ports.
    Actually, I can't understand your last sentence. If analog sources resolutions are lower than mp4 resolutions, does it cause problem? Our aim is to capture in mp4 format and play mp4 files on TVs or computers without any problems. Should I consider something before I get one of these capture devices?
  4. Mod Neophyte redwudz's Avatar
    USA
    I have a Hauppauge HD PVR 2 and it can capture in MP4 or .TS or .M2TS format with a HDMI input.
    I haven't used WinTV 8 software. But anything that outputs a
    HDMI signal you should be able to capture directly to MP4.
    I don't have the AV in cable, so I've never tried that.
    I bought it off Ebay, and cables weren't included.
    I have this model: http://www.hauppauge.com/site/products/data_hdpvr2-gaming.html
  5. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    What I was trying to say was that if you record HD programming, like 1080i content then your recording will also be interlaced and need to be deinterlaced by the player.
    If you are planning on capturing analog SD formats like Video8, VHS, Hi8, and others then you will need to deinterlace, either with the Colossus or with a second re-encoding. Your HD tape might also be interlaced.
    MP4 is a container along with .MKV and .TS (can think of them like a ZIP or RAR) and has no resolution restrictions apart from the restrictions the placed on the video formats it can contain, like H.264. There are restrictions above 4k with H.264 but you won't run into those here.
    Jul 2003
    Turkey
    If we use one of these products, do we have to wait for deinterlace process after capture? Should the deinterlace process be done after capture or during the capture? Does it take much time to deinterlace a 4 GB captured file? And is it nonsense capturing analog videos to mp4? I'm sorry, I don't have enough information about capturing from analog to HD. I thought, I could capture videos in mp4 format from analog sources in real time without any problems and extra processes.
  7. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    That's the thing, the Colossus might have options for deinterlacing and then outputting progressive content which you would need, but I don't know if the Colossus can do that or not.
  8. All the information you are looking for is available on their web site.
    To answer your question very easily though, YES! The hauppauge hd pvr DOES output an MP4 file that is ready for whatever you want when it is done. I use mine to record boxing through my satellite service.
    It seems like I do only capture in 720p as a rule. I can't remember why exactly that is but it could have been because of the "interlace" as mentioned above.
    Realtime deinterlace is always ghastly stuff.
    Don't do that if quality matters.
    Nov 2006
    Are you saying capturing at anything other than 480i would be real-time deinterlacing? (480p output would mean it's been deinterlaced)? My video processor outputs at 480p, 720p & 1080i. Is it better to capture at 1080i due to the same frame rate as the source?
    Aug 2006
    Yes, he is saying that.
    1080i would be worse than 480p. In order to produce 1080i output from 480i input, the video must be deinterlaced to 480p, then upscaled to 1080p, then re-interlaced to 1080i, in real time.
    A quote from one of my posts in one of your other threads:
    480i captures are the best way to go for NTSC interlaced video, especially for a video created from a film source. What will it take to make you believe we really do mean that this is the best way to go?
    Nov 2006
    Thank you usually_quiet. You've helped me a lot in the past on my laserdisc capture questions. I'm still deciding the best capture method. I did buy the best processor out there (Lumagen 2144) due to it's 3D comb filter. But the lowest rez is 480p via hdmi. The 2144 does have pretty good upscale to 1080i, but like everyone recommends I'd rather upscale in post.
    I have been looking into a dvd recorder like you recommended to capture at 480i via component.
    One major problem is Windows 7 is going away in two years. Some capture devices won't work with 10.
  13. If you have money: https://www.aja.com/products/io-express#techspecs
    There are cheaper (and older) aja cards out there though
    Nov 2006
    Thank you themaster. I've recently been looking into AJA products. But whatever I get I'll thinking it will be a pci/e card. They seem to have a bunch of good ones.
  15. Those Hauppauge devices will lock up frequently if you try to capture VHS and other sources with poor time base (especially if you FF or RW). You'll have to power cycle them to get them back online.
