If I chose everything correctly, then it should be compress with losses that can not be seen even on a black background with noise? And why am I getting an error?
[Attachment 44626 - Click to enlarge]
[Attachment 44627 - Click to enlarge]
It means it will compress everything losslessly. There will be no loss if you use the same bit depth and colorspace. If your black background had noise, it will preserve the black background and the noise . It just means the uncompressed input = decoded output
High 10 profile does not support lossless encodingAnd why am I getting an error?
High 444 profile is required or just leave it "auto" if you don't know what you're doing -
Try profile=auto instead of high10.
After you get an error, click View menu, Log, then right-click, Copy to clipboard.
Paste it into your text editor. This is what I get:(This is better for posting than a screen shot, too)Code:[*] Beginning dub operation. [i] Dub: Input (decompression) format is: YUV420. [E] x264 [error]: high10 profile doesn't support lossless [E] x264 [error]: x264_param_apply_profile failed [E] Error: Cannot start video compression: An invalid parameter was specified. (error code -6) [*] Ending operation.
Convert techsmith( camstasia codec) to x264 ?
By Bobby747 in forum Video ConversionReplies: 4Last Post: 17th Jun 2017, 06:02 -
Can't use Codec compression in PowerDirector 13 ?!
By white1 in forum EditingReplies: 3Last Post: 26th Oct 2015, 19:56 -
How to achieve mp4(x264) compression of Debut Video Capture in Sony Vegas
By Lukis in forum Video ConversionReplies: 19Last Post: 15th Feb 2014, 18:43 -
encoding with x264 and h264 codec only use 30-50% cpu
By Slind in forum Video ConversionReplies: 32Last Post: 26th Nov 2013, 20:29 -
Maximum bitrate for the x264 profiles and levels
By wotdefcuk in forum Video ConversionReplies: 1Last Post: 26th Feb 2013, 18:45
