Hi all, I hope I'm i the right section.
I'm trying to save some old 8mm camcorder tapes and was going to capture them, but I have an issue with my camcorder. It's an old Samsung VP-W60 and the issue is that I'm only getting audio out of one speaker when I hook it up to various devices.
The connection for output on the camcorder is from a single 1/8inch A/V out jack socket which carries the video and the audio as well. I tried no less than three cables (one bought only today) but the audio still only comes out of one speaker.
I've tried it on my computer and on my TV to see if the problem persisted and it did. I'm using an 18/inch jack to composite/component (red, white. yellow) cable and that is plugged into a composite -> scart adaptor which is then plugged into my TV. The same issue happens when I plug direct into the computer using the composite.
Could the camcorder itself be at fault? I'd hate to think so because it would lave me stuck.
Many thanks!
That camera records in mono and your plug is probably stereo. Your best bet is probably to ignore the right channel and get an additional splitter for the left.
Ahh ok thanks. The footage was actually recorded on another camcorder (a Sony I think) but regardless I'll just do as you say. Would it be the same result if I just duplicated the audio track and flipped the stereo image of one of them and then exported?
It's much easier to get a stereo Hi8/Video8 camcorder or a Digital8 camcorder with Hi8/Video8 playback, I just picked one up locally for $20 to transfer some tapes.
Audio and video coming through on different AV channels on TV
By DRM32 in forum DVB / IPTVReplies: 5Last Post: 16th May 2017, 12:38 -
Wireless speaker options
By Darth Paris in forum Off topicReplies: 2Last Post: 11th Dec 2014, 09:19 -
Retro tv shows sound like broadcast audio was captured off a speaker
By brassplyer in forum Newbie / General discussionsReplies: 5Last Post: 15th Apr 2014, 23:58 -
Problems with Audio through one speaker.
By Oxymoron28 in forum AudioReplies: 1Last Post: 13th Apr 2014, 18:51 -
best brands speaker PC
By gamemaniaco in forum ComputerReplies: 52Last Post: 2nd Oct 2013, 22:27
