So I have a daily task of reviewing a variety of news programming and from that I need to capture certain highlights. I have a GTX950 2G GPU and was wondering if the game capture capabilities of Nvidia cards would help me do this?
Ideally the easiest thing for me would be to cue up the programming (avi, mkv, mp4 files) in full screen mode and somehow be able to record/pause with a hotkey combo to a single output file. Volume may need to be normalized afterwards, resolution differences are not important. Dunno, I would really like to avoid creating individual clips and then trying to combine them.
Is there an easy way to do this? I dont have the time to be screwing around with software suites and or splitting/combining avi's etc. TIA
	Do you mean Nvidia ShadowPlay? Reading one of the guides, ShadowPlay doesn't seem like something which would be useful for making screen captures from random news shows. ShadowPlay is screen recorder/screen capture software designed specifically for making screenshots and short clips of game highlights. It is unlikely that clips are saved in a big file containing many clips. They are probably saved individually. Given the questions that you are asking about ShadowPlay, it doesn't seem like you have used it, so you would have to learn something. Ignore list: hello_hello, tried, TechLord, Snoopy329
	I have used it in game, never for what I am talking about, which is basically having a FS recording session in the background that I can pause/resume. I thought someone here would know if any of the Nvidia utils would work. Basically I just need a "screen recorder" if there is such a thing. Even if a utility did make individual clips, merging them would only be one more step so thats acceptable.
 In any event I found a util called faststone capture, so will try that, seems to do what I want. thanks.
	I did a little more searching and found some YouTube tutorials explaining how to use ShadowPlay to record the screen when a game is not being played:
 https://www.youtube.com/watch?v=czGFyXd8kfo
 https://www.youtube.com/watch?v=tNepPm9dpZc
 So, it is possible to use ShadowPlay record the screen. However, with no NVIDIA video card, I can't try it myself to see if it works well for that.Ignore list: hello_hello, tried, TechLord, Snoopy329
  DVD menu highlights problem!By dilophosaurus65 in forum Authoring (DVD)Replies: 4Last Post: 17th Aug 2015, 05:17
  Where can I get a reel to reel tape transferred?By stantheman1976 in forum AudioReplies: 3Last Post: 27th Apr 2015, 12:17
  Help- For downloading WC match highlights from fifa.comBy abhishek12 in forum Video Streaming DownloadingReplies: 0Last Post: 8th Jul 2014, 07:37
  Subpicture highlights look jagged on TVBy Henkie in forum Authoring (DVD)Replies: 9Last Post: 10th Feb 2014, 14:08
  5 Inch Reel to Reel Tape QuestionBy daave in forum AudioReplies: 17Last Post: 20th Mar 2013, 16:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
