Could someone tell me just what happened here?
I 19:27:47 ImgBurn Version 2.5.8.0 started!
I 19:27:47 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 19:27:47 Total Physical Memory: 6,157,592 KiB - Available: 3,643,108 KiB
I 19:27:47 Initialising SPTI...
I 19:27:47 Searching for SCSI / ATAPI devices...
I 19:27:47 -> Drive 1 - Info: HL-DT-ST BD-RE BP50NB40 1.00 (E(USB 2.0)
I 19:27:49 -> Drive 2 - Info: HL-DT-ST DVD+-RW GT80N A103 (D(SATA)
I 19:27:49 Found 1 DVD±RW/RAM and 1 BD-RE XL!
I 19:28:18 Operation Started!
I 19:28:18 Source File: C:\Users\Desktop\BHOP4.iso
I 19:28:18 Source File Sectors: 11,587,936 (MODE1/2048)
I 19:28:18 Source File Size: 23,732,092,928 bytes
I 19:28:18 Source File Volume Identifier: Untitled Project
I 19:28:18 Source File Volume Set Identifier: 12345678 BDROM
I 19:28:18 Source File Application Identifier: BD Authoring
I 19:28:18 Source File Implementation Identifier: Developer
I 19:28:18 Source File File System(s): UDF (2.50)
I 19:28:18 Destination Device: [0:0:0] HL-DT-ST BD-RE BP50NB40 1.00 (E(USB)
I 19:28:18 Destination Media Type: BD-R (Disc ID: VERBAT-IMe-000)
I 19:28:18 Destination Media Supported Write Speeds: 2x, 4x, 6x
I 19:28:18 Destination Media Sectors: 12,219,392
I 19:28:18 Write Mode: BD
I 19:28:18 Write Type: DAO
I 19:28:18 Write Speed: 4x
I 19:28:18 Hardware Defect Management Active: No
I 19:28:18 BD-R Verify Not Required: Yes
I 19:28:18 Link Size: Auto
I 19:28:18 Lock Volume: Yes
I 19:28:18 Test Mode: No
I 19:28:18 OPC: No
I 19:28:18 BURN-Proof: Enabled
I 19:28:20 Write Speed Successfully Set! - Effective: 17,984 KB/s (4x)
I 19:28:41 Filling Buffer... (80 MiB)
I 19:28:42 Writing LeadIn...
I 19:28:44 Writing Session 1 of 1... (1 Track, LBA: 0 - 11587935)
I 19:28:44 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 11587935)
W 19:51:11 Failed to Write Sectors 9874848 - 9874879 - Reason: Write Error
W 19:51:11 Retrying (1 of 20)...
W 19:51:11 Retry Failed - Reason: Invalid Address For Write
W 19:51:11 Retrying (2 of 20)...
W 19:51:11 Retrying (3 of 20)...
W 19:51:11 Retrying (4 of 20)...
W 19:51:11 Retrying (5 of 20)...
W 19:51:11 Retrying (6 of 20)...
W 19:51:11 Retrying (7 of 20)...
W 19:51:11 Retrying (8 of 20)...
W 19:51:11 Retrying (9 of 20)...
W 19:51:11 Retrying (10 of 20)...
W 19:51:11 Retrying (11 of 20)...
W 19:51:11 Retrying (12 of 20)...
W 19:51:11 Retrying (13 of 20)...
W 19:51:11 Retrying (14 of 20)...
W 19:51:11 Retrying (15 of 20)...
W 19:51:11 Retrying (16 of 20)...
W 19:51:11 Retrying (17 of 20)...
W 19:51:11 Retrying (18 of 20)...
W 19:51:11 Retrying (19 of 20)...
W 19:51:11 Retrying (20 of 20)...
W 19:51:31 Retrying (21)...
W 19:51:31 Retry Failed - Reason: Invalid Address For Write
W 19:51:32 Retrying (22)...
W 19:51:32 Retry Failed - Reason: Invalid Address For Write
E 19:51:33 Failed to Write Sectors 9874848 - 9874879 - Reason: Write Error
E 19:51:33 Next Writable Address: 0
I 19:51:33 Synchronising Cache...
W 19:51:47 User opted to skip the 'Close Track/Session/Disc' functions.
E 19:51:47 Failed to Write Image!
I 19:51:47 Exporting Graph Data...
I 19:51:47 Graph Data File: C:\Users\Gabe Lewis\AppData\Roaming\ImgBurn\Graph Data Files\HL-DT-ST_BD-RE_BP50NB40_1.00_TUESDAY-FEBRUARY-6-2018_7-28_PM_VERBAT-IMe-000_4x.ibg
I 19:51:47 Export Successfully Completed!
E 19:51:47 Operation Failed! - Duration: 00:23:29
I 19:51:47 Average Write Rate: 14,436 KiB/s (3.3x) - Maximum Write Rate: 17,857 KiB/s (4.1x)
LTH discs is the problem ... not all burners like them ... choose in imgburn test mode next time and set speed to 2x to confirm issue remains
If pass it should be safe to proceed with burn ... if not then your choice is limited
Burning over usb has many issues ... better to use internal system unit -
They aren't LTH discs and test mode isn't going to help here as if it isn't trying to actually write data to the disc, it'll never know if it can or not.
Your drive reported a 'Write Error', so it didn't like something about the disc.
Pretty much all you can do is try another one.
If it fails again, perhaps try enabling the 'Perform OPC Before Write' option on the 'Write' tab within the Settings. -
Thanks gentlemen. I was about to flip freaking s#!t with the LTH thing. I went through the process of making sure the exact discs I bought weren't. They are Verbatim discs and this is the first issue I've had.
Layer Break error when burning with ImgBurn
By Keyser in forum Authoring (DVD)Replies: 3Last Post: 2nd Sep 2017, 17:14 -
Burning blu-ray video with ImgBurn
By gliebisch in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Aug 2016, 23:25 -
2 Layer DVD Burning with ImgBurn
By niteghost in forum Newbie / General discussionsReplies: 9Last Post: 30th Jul 2014, 19:37 -
ImgBurn error, dying DVD drive?
By Instant Martian in forum DVD & Blu-ray WritersReplies: 34Last Post: 14th Jul 2014, 08:46 -
Burning video to DVD with ImgBurn, why does it burn twice ?
By chris_2012 in forum Authoring (DVD)Replies: 15Last Post: 9th Mar 2013, 13:49
(USB 2.0)
