Hi Guys, I am having a problem with a dim screen. I have tried to reinstall a new display driver, but the dialog box options say I have the latest driver installed. Can I uninstall the current driver? What happens to my screen if I uninstall the current driver?
I want to uninstall, reinstall the driver to make sure that the one installed it is not corrupted or defective?
I installed a Linux Mint 17 distro onto this laptop on a separate HDD, and have since learned that this distro has issues with or / creating a dim screen on computers? I have also tried holding down the FN key and tapping the lightbulb key on my Dell Latitude D620, didn’t work. When using the laptop with internal battery the screen is dim, when AC adaptor cable is attached the screen returns to normal. Any ideas how to get the screen back to normal. Cheers visionman
Health IS the first Wealth------So do not strain your eyes!
sounds more like a power saving "feature" to me. see what your setting is in control panel/power options
Uninstalling the video drivers will only trigger the os to use universal drivers at lower resolution
For linux mint goto Screensaver & Lock settings for brightness controls > un-tick checkbox to "Dim screen to save power" -
Thanks aedipuss and Bjs both right , I fixed it very simply . I was trying the FN keys with the wrong additional key. I should have used the FN key with the arrows up and down keys. The little icon appeared and fixed the problem instantly. Albeit, after 3 months wondering how to fix it before posting!
Many thanks guys, I was not sure what this problem was, your advice gave me the additional get up and go to have another crack at it, and for the additional info regarding Linux mint, thanks
Passkey uninstall help needed- failure to uninstall conflicts with AnyDVD
By loninappleton in forum Newbie / General discussionsReplies: 22Last Post: 19th Sep 2017, 11:20 -
NVIDIA Display Driver 378.49
By jseidel in forum Software PlayingReplies: 3Last Post: 3rd Feb 2017, 20:20 -
Display Wide Screen?
By TB Player in forum Capturing and VCRReplies: 5Last Post: 8th Jul 2013, 06:49 -
Media Player Home Cinema Display Issue
By Fulcanelli in forum Newbie / General discussionsReplies: 16Last Post: 14th Apr 2013, 07:45 -
incompatible display driver with adobe premier elements 11.0
By godefroy in forum ComputerReplies: 2Last Post: 31st Mar 2013, 19:45
