I have one computer running Windows 7 x32. I build a new computer which is running Windows 10 Pro x64. I create all my subtitles using SubtitleEdit. I am using different SubtitleEdit builds on each system. When I created a VobSub subtitle on the x32 system for a 1280x720 video I set the font size at 35. When I create a VobSub subtitle for a 1280x720 video on the x64 system I have to set the font size to 55 or 60 to get a comparable display size as on the x32. Why is that?
When I first created a subtitle on the x64 machine using my old font sizes and added it to my video and then watched it on the flat screen I could hardly read it.
I could be wrong but I doubt the author made an internal change to the program just as I built my new system. As far as x32 vs x64 I thought the only difference was addressing memory. Again, I could be wrong.
Just curious why the difference, if anyone knows.
sneaker,
Thanks for the quick response.
All my settings are the same on both systems and both systems have the same font.
I now only use my x64 system to produce VobSub subtitles so I am adjusting to the new/different settings.
I'm not that interested in investigating why the difference.
I put the question out there just in case there was something obvious that I was missing.
I am unaware of any setting in SubtitleEdit that would cause the need to double the font size from a x32 system to an x64 system.
Thanks again for the response.
How do I enable MODI in SubtitleEdit?
By Oath in forum SubtitleReplies: 4Last Post: 25th Jun 2018, 14:13 -
SubtitleEdit command line export EBUSTL options
By Juanjo04 in forum SubtitleReplies: 0Last Post: 30th May 2017, 10:52 -
Staxrip x64-1.4.0.0
By brusno in forum Video ConversionReplies: 9Last Post: 24th Feb 2017, 18:14 -
x64 MeGUI DirectShowSource
By darkw1zard in forum Video ConversionReplies: 9Last Post: 1st Sep 2014, 16:16 -
FFMPEG for APACHE 2.4.6 (x64), PHP 5.5 (x64), MYSQL 5.6 (x64) on WINDOWS 8
By Punctual in forum Video ConversionReplies: 5Last Post: 7th Aug 2013, 19:41
