Hello
I watch most of my blu-rays on my PC but in powerdvd theres no option to capture a screen of the blu-ray menu and extras (I mean Powerdvd has an option to capture screens but its not abled when it comes to blu-ray menus), something I've always wanted to do. I've downloaded several programs to watch my blurays on my computer but none seem to have this option abled when it comes to blu-rays, though its quite easy to do with a normal DVD
is there a way to take a good screencapture of the extras of a blu-ray? which software would require?
thanks in advance for any help
Sort of basic, but if you just need a static screen grab, PrtScn on your keyboard and open with MS Paint.
Licensed Blu-ray player software must use a protected path when playing a copy-protected disc to prevent anyone from copying the movie by making a screen capture
There is only one way that I know of to take a screenshot with PowerDVD while playing the original Blu-ray and that is to run a decrypter like DVDFab Passkey for Blu-ray or AnyDVD HD in the background while playing it.
Since it isn't licensed by the BDA, Leawo Blu-ray player might allow making screenshots, but I don't have it and can't guarantee that it will do what you want or even play your movie.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
thanks, so it seems its quite complicated. Since its quite easy to do it with DVDs and I thought the same rules would apply to blu-rays I was suprised to read its actually a different scenario
CDs had no copy protection, and manufacturers hated that, so they put CP on DVDs. But consumers didn't have too hard of a time getting around that so when BD came out, they doubled down on the CP. Even moreso with UHDBD (4k).
Edit/add to blu ray menu
By adzyu100 in forum EditingReplies: 4Last Post: 25th Jan 2015, 11:24 -
The menu doesn´t appear in Blu-ray
By Vicentovsky in forum Authoring (Blu-ray)Replies: 11Last Post: 6th Aug 2014, 05:04 -
Cinemagraph to Blu Ray Menu
By PsymonBlu in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2013, 17:39 -
Blu-ray playing software that I can screencap from?
By AmethystMina in forum Software PlayingReplies: 2Last Post: 22nd Mar 2013, 18:07 -
Restructure the Blu-ray Menu
By jayzoli in forum Blu-ray RippingReplies: 1Last Post: 8th Mar 2013, 00:49
