    Feb 2018
    Germany
    example: https://youtu.be/u842VC5XBmw?t=23s
    I'm using premiere pro and I'm completely new and trying things out. How do I make the video blurry for a short time and then the fade into normal sharpness?
    I can just manage to blur it completely without a transition.
    Thanks in advance!
  2. Add keyframes to the beginning middle and end your blur in the effect control editor and adjust the amount of blur per keyframe.
