Hi there,
I've watched the (YT) Mad Max Fury Road Black & Chrome trailer and am now wondering if that's a simple color to grayscale conversion
I'd like to recreate that with an Avisynth script. Any suggestions?
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
Assuming your colour space is YCbCr then http://avisynth.nl/index.php/Limiter will do work Limiter(16, 235, 128, 128) - personally think that 'chrome' mean overexposure white with high contrast - you can use LUT to get more pleasant effect. (there is also possible to use overlay in multiply mode).
Also there is too much different results from different film brand and their different products. Each results in different B&W result.
Berni -
Check this, it is not just darker lighter, but in darkest bottom it doesn't mean, that sky are also darker. Most of them seems to be identical, but they are not.
Here is link because size is over 2MB
Unfortunately it is created in painting program, not in avisynth or any other video program. If you can somehow create batch it can be useful for you. And there is some video program that is using GMIC, but it is for linux I think.
Bernix -
I guess I'll stick with the Limiter solution for now
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
Thanks for this !
Which "demux" program extracts audio & video from various file formats?
By jaibubwan in forum EditingReplies: 11Last Post: 18th Oct 2017, 15:20 -
What is the purpose of "Default" button in "Video" tab of XMedia Recode?
By MidnightUser in forum Newbie / General discussionsReplies: 1Last Post: 15th Jan 2016, 04:08 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
Why 16:9 "Original" & 16:9 "Full" settings on Blu-Ray player....?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Apr 2015, 09:13 -
Can Someone Recommend a Blu-Ray Player that can read "BD-R" & "DVD-R" ?
By THEBDC in forum DVD & Blu-ray PlayersReplies: 6Last Post: 17th Mar 2015, 18:03
