    May 2002
    Manchester UK
    Right I've done it. My Macbook Pro's Logic Board died a death and I've gone to W10. I bought a Pioneer Bluray writer and some 25Gb discs.
    What software would anyone recommend to me to be able to make Bluray disc, please. . Any help appreciated. My PC is an Asus ViviBook S14 and seems to be up to the job.
    Any help gratefully appreciated.
    I would say I'm a 5 out of ten for tech savviness
    carpe diem maņana
    USA
    For freeware, maybe multiAVCHD
    Others here: https://www.videohelp.com/software/sections/authoring-bd-hd-dvd
    Or here: https://www.videohelp.com/software/sections/all-in-one-blu-ray-converters
    It can get complicated and/or expensive.
    And I would highly recommend ImgBurn to burn the disc. And Verbatim BD discs.
    May 2002
    Manchester UK
    I downloaded multiAVCHD and it seemed to go well but then I got avsintho.exe missing message. Any idea what that might be?
    carpe diem maņana
  4. avsintho.exe
    Could this be AVSInfo.exe? It's supposed to be in [Installed path\]multiAVCHD\tools.
    May 2002
    Manchester UK
    Yes. That was it ? Sorry to be a pain, but how do you do that?
    carpe diem maņana
  6. Looked in my installation for multiAVCHD. Perhaps try to re-install.
    multiAVCHD has the advantage of encoding your mkv to meet the specifications for Blu-ray (look at the upper right corner at Videohelp "What is") if needed.
    If your mkv already meet the specifications tsMuxerGUI is very easy to use to create a BD iso to burn with ImgBurn.
  7. BD Rebuilder to convert from MKV to Blu-ray structure and ImgBurn to burn to disc.
  8. I'm a Super Moderator johns0's Avatar
    canada
    You need to install AviSynth for multiavchd and java if you don't have that installed.
