I am completely new to the forum, so forgive me if this is the wrong area to be posting this.
I want to learn how to convert Blu-Ray files to MKV, preferably, or at least some other format which is actually playable on the PC.
Is this possible to do with MKVToolNix?!
Results 1 to 9 of 9
I use VidCoder.
But other members may give you better advice about MKVToolNix. -
I was instructed to use MakeMKV, which is free until February, which worked.
I was informed that MKVToolNix only lets you manipulate MKV files, so it isn't very useful in this situation.
Does VidCoder allow me to convert "movie objects" (or Blu-Ray files) to MKV or other formats?!
Thanks -
Keep in mind that MkvToolNix does not re-encode the audio or video. It just takes the streams out of the source container and re-multiplexes them into an MKV container. Hence the MKV audio and video will be exactly the same quality as the Blu-ray source. And about the same size. If you're looking to squeeze a 25 GB Blu-ray rip down to a 5 GB MKV you need to re-encode, not re-mux.
Best way to convert an MKV file to Blu-ray?
By hbenthow in forum Authoring (Blu-ray)Replies: 28Last Post: 21st Jan 2022, 08:05 -
How to backup and convert Blu-ray to MP4 HD or MKV HD
By Baldrick in forum User guidesReplies: 360Last Post: 13th Nov 2017, 00:51 -
Convert MKV to Blu-ray
By chang123 in forum Authoring (Blu-ray)Replies: 11Last Post: 12th May 2016, 14:00 -
Blu-ray player that will play MKV files off a BD-R?
By ampex in forum DVD & Blu-ray PlayersReplies: 12Last Post: 31st Aug 2014, 00:53 -
Will convert my b) Blu-ray collection to MKV REMUX but??
By botdvd in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2013, 03:06
