I am new to video authoring. I used Movavi Video Studio to capture a video stream of my son's college baseball games. File sizes are about 11-15GB for 3 hour games
The file was saved in MP4 video, currently on my laptop and backed up on a rotating drive. I can watch the file fine on my laptop
I would like to put the games on Blue-Ray disks so my wife or parents can watch replays on their Blue-Ray/DVD player at home.
I have an LG WH16NS40 Blue-Ray writer and Movavi Video Studio 16 software (Win10 Pro, 8G RAM, 1TB SSD)
So far, I am unable to create a Blue-Ray disk I can watch on TV in my living room. My first attempt, following the directions to burn a disk, had the SW replay the entire video (3 hrs) as it converted the video. When I finished I got an error saying "program stopped working". This happened twice.
I tried to burn another game file. The file burned on the Blue-Ray (I can see the coloration) and the Sony Blue-Ray in my living room sees it, but it won't play. When I burned the disk there were some errors at the end of the process, different from the "program stopped working" error. It said something about not being able to read memory...I didn't get a screen capture.
I found a menu in Movavi for "TV readable" file or something like that, but it makes the file 31GB, too big for a standard BD and I don't know if this is the right path or not, so I don't want to by 2xBD just to try it out.
How do I take my MP4 file and put it on a Blue-Ray disk I (or my parents) can watch in my living room?
Thank you
	Some Blu-ray players can play media files burned on a Blu-ray disc as data, but others cannot or are very limited with respect to the types of media files that they can play. Your best bet is to author a Blu-ray disc to ensure playability. You can probably put about 2 hours of HD Blu-ray-compatible video on a BD-R 25GB disc.
 Authored Blu-ray has a set of requirements for video and audio. (See "What is Blu-ray", accessible by clicking "What Is" at the top of a VideoHelp web page.) It would be helpful for us to know how close your original screen capture is to meeting them. Please post a MediaInfo report for the file containing your original screen capture.
 Instructions:
 Download and install MediaInfo.
 Open the file with MediaInfo.
 Click on "View" in the menu bar and select "Text" from the drop-down menu.
 Copy the resulting report and paste into a new post in this thread.Ignore list: hello_hello, tried, TechLord, Snoopy329
	Thank you for your reply.
 Here is the MediaInfo file
 General
 Complete name : E:\Baseball videos\Movavi Screen Capture\Alec Start.mp4
 Format : MPEG-4
 Format profile : Base Media
 Codec ID : isom (isom/iso2/avc1/mp41)
 File size : 11.0 GiB
 Duration : 3 h 15 min
 Overall bit rate : 8 100 kb/s
 Writing application : Lavf57.40.101
 Video
 Format : AVC / AVC
 Format profile : Baseline@L4 / Baseline@L4
 Format settings : 1 Ref Frames / 1 Ref Frames
 Format settings, CABAC : No / No
 Format settings, RefFrames : 1 frame / 1 frame
 Format settings, GOP : M=1, N=25 / M=1, N=25
 Codec ID : avc1
 Bit rate : 7 899 kb/s
 Width : 1 588 pixels
 Original width : 1 588 pixels / 1 588 pixels
 Height : 898 pixels
 Original height : 898 pixels / 898 pixels
 Display aspect ratio : 16:9
 Frame rate mode : Variable
 Frame rate : 29.276 FPS
 Minimum frame rate : 14.927 FPS
 Maximum frame rate : 30.296 FPS
 Color space : YUV
 Chroma subsampling : 4:2:0 / 4:2:0
 Bit depth : 8 bits / 8 bits
 Scan type : Progressive / Progressive
 Bits/(Pixel*Frame) : 0.189
 Stream size : 10.8 GiB (98%)
 Audio
 Format : AAC
 Format profile : LC
 Codec ID : mp4a-40-2
 Bit rate mode : Variable
 Bit rate : 192 kb/s
 Maximum bit rate : 256 kb/s
 Channel(s) : 2 channels
 Sampling rate : 44.1 kHz
 Frame rate : 43.066 FPS (1024 SPF)
 Compression mode : Lossy
 Stream size : 264 MiB (2%)
 Default : Yes
 Alternate group : 1
	I can play this file from my laptop to my TV via an HDMI cable
 I would like to copy to a BD-R disk I can save and I can send copies to grandparents. This video is from last year and the season starts shortly so I am trying to figure out how to get them onto Blue-Ray disks to watch from a BD player
	Your captured video and audio is not very close to being Blu-ray compliant. Your capture contains 1588x898 resolution progressive video at a variable frame rate of 29.276 fps, using AVC for video and AAC for audio.
 The closest thing to that which Blu-ray supports is 720p59.97 = 1280x720 resolution progressive video at a constant framerate of 59.94 fps, using AVC for video and Dolby Digital for audio.
 Is there any chance that the game is still available via streaming? I think that if it is possible to capture the stream itself with something like youtube-dl-gui, you might be able to get something a bit better to work with.Ignore list: hello_hello, tried, TechLord, Snoopy329
	It should still be possible to convert your screen captures to Blu-ray if the video for these games is no longer available via streamin.
 The variable frame rate is the biggest problem with your screen captures. That must be corrected first. Some advice I found here at VideoHelp suggested it is possible to change variable frame-rate video which results from frame drops into constant frame rate video by using TSMuxer GUI to re-mux the video from MP4 to TS. Select TS muxing (under the Output section on the Input tab) and check the change frame rate option and set the frame rate to "30000/1001" (look for these settings under the "General Track" options on the Input tab). Unfortunately, you can't use TSMuxer to author a Blu-ray disc until you have converted the video to be Blu-ray compliant with other software.
 I'm not the best one to give advice on what beginner-friendly free software you should use to re-encode the video. I have PowerDirector, which can both convert video for Blu-ray and author a Blu-ray disc, but I have not tried it for conversion. Anything that I have authored as a Blu-ray disc was already compliant with the spec. There may be better options available for you.Ignore list: hello_hello, tried, TechLord, Snoopy329
  Burning 3d mkv file to blue ray 3dBy Poetheraven1 in forum Authoring (Blu-ray)Replies: 22Last Post: 30th May 2016, 10:29
  how i can improve blue-ray video qualityBy plaban in forum Newbie / General discussionsReplies: 2Last Post: 18th Nov 2015, 22:26
  Pot Player Blu-Ray Time-On-Screen in Full-ScreenBy robertkjr3d in forum Software PlayingReplies: 2Last Post: 31st Oct 2014, 05:46
  Authoring standard Blue Ray video from AVCHD - Need general guindanceBy rodrigonh in forum Authoring (Blu-ray)Replies: 1Last Post: 9th May 2013, 00:24
  What might cause a USB capture device driver to suddenly blue-screen?By Brad in forum Capturing and VCRReplies: 11Last Post: 30th Mar 2013, 04:22
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
