Hello everyone,
I'm currently using Subtitle Edit 3.5.5 and working on a TV show. I got lots of scenes with main characters and less important ones. Main characters have colors assigned to them (ex. Tom is blue and Chris is green) while less important ones remain white. When I add colors they display correctly, but when I save the file (using EBU STL format) and re-open it, only one color remains.
example
before re-opening
<font color="Green">- Hey man, how's it goin?. </font>
<font color="Yellow">- Hey, long time no see! </font>
after re-opening
Anyone have any ideas? I'm in a pinch
Regards,
Tom
Results 1 to 12 of 12
Hi,
in subtitle edit open it, then in files there is Ebu stl properties or something like this. It states here, color needs to teletext, which isn't choose by default, try both teletext option.
Let me know if it helped you.
Bernix -
Hey Bernix,
I've tried already all of the options in EBU STL properties (0,1,2,unidentified) and sadly none of them solved my problem.
Regards,
Tom -
Hi,
another idea. Try different software, or contact author of Subtitle edit. From my experience he is really quick in answering question, add features, bug fixes and so.
Bernix -
Hey,
I've already contacted Nikolaj and waiting for any response. Except Subtitle Edit and FAB Subtitler I don't know about any other software that supports EBU STL subtitles, but if by any chance you know any (I've done some research before but no luck), then please let me know
Regards,
Tom -
Another idea, have you try Export instead of save as ? Probably there is some difference.
Bernix -
Hey Bernix,
I've tried exporting and still no good. Problem dosen't exist for *.srt files... So it might be format specific issue.
Regards,
Tom
ps. gonna wait till tomorrow for some response from the creator, after I'll look for some alternative which I'll hopefully find. -
Does the program generate that code ?
It does not look correct with text being encased in a font tag. The guides I read for the EBU format also require a prefix such as 'tt:color ='Green' ' but not part of the font tag. -
Hey,
yes, Subtitle Edit generates such tags when coloring.
Regards,
Tom -
A little update...
I've contacted with Nikolaj and issue have been resolved. Thank you everyone for help and input in this topic.
Regards,
Tom -
Since the forum also exists for people coming later and having similar issues can you enlighten us in how the issue was resolved ?
shooting colored LED lights
By Wwm2 in forum Newbie / General discussionsReplies: 8Last Post: 7th Jun 2016, 14:45 -
PotPlayer and colored text (SOLVED)
By suadnovic in forum Video Streaming DownloadingReplies: 7Last Post: 30th Nov 2015, 04:55 -
multi-colored shadows
By moparbrian in forum Newbie / General discussionsReplies: 9Last Post: 11th Dec 2014, 11:03 -
Event Pan/Crop Dialogue Box Tab, revert to Dialogue Box?
By saiiyu in forum EditingReplies: 2Last Post: 10th Feb 2014, 15:26 -
Remove semi-transparent colored logo with XLogo?
By Brad in forum RestorationReplies: 0Last Post: 7th Dec 2013, 13:05
