I was using Smart Buy DL discs for a while and they were pretty good. Not a bad failure rate. But lately, they've been out of stock on them so I took a chance and tried these Tiger brand discs I found on ebay. They suck. The media ID on them is CMC MAG-D03-64
So I decided to buy some Verbatim as I read they're supposedly the best. They just arrived today and I look at the media ID and it's the same as the Tiger, CMC MAG-D03-64
I'm definitely not going to use these Verbatims and will return them promptly since they have the same media ID as these lousy Tiger discs.
So my question, is what is the best inkjet printable dual layer DVD disc to buy at present, that's readily available? Thanks!
Results 1 to 10 of 10
You must've bought Verbatim's Life Series, not their own AZO discs.
Ahhhhhh, it seems you're right, it does say Life Series. Darn it. So I guess it's these I should be seeking?:
https://www.amazon.com/Verbatim-8x-10x-Branded-Recordable-97000/dp/B005F2YPH2
Any other suggestions for quality discs or don't bother with any except the Verbatim AZO ?
EDIT: I should mention that the discs need to be white inkjet printable, so the above won't work for me. Seems the AZO isn't available in this format?Last edited by sdsumike619; 31st Jan 2018 at 18:32.
For DL, it's Verbatim or bust: http://amzn.to/2Fydqwu
Just under $1 per disc.
Eh, not bad. Price it's been at for years now, for a legit MKM disc.Want my help? Ask here! (not via PM!)
Are these good?
Verbatim DVD+R DL 8.5GB 8X DataLifePlus White InkJet Printable, Hub Printable, 50 Disc Spindle 98319
http://a.co/3wmCDgV -
Thanks, I've gone ahead and ordered them. Any idea what the media ID should be on these when I check them?
Splitting dual-layer ISO to two single-layer ISOs
By Electrojim in forum DVD RippingReplies: 8Last Post: 21st Apr 2017, 14:43 -
Dual Layer DVD question...?
By Bansaw in forum EditingReplies: 12Last Post: 28th Oct 2016, 20:37 -
Converting 8 VCDs into one dual-layer DVD
By Slickrobie in forum Authoring (DVD)Replies: 3Last Post: 25th Nov 2013, 04:32 -
dual layer burning dvd error
By saleen_gt in forum Authoring (DVD)Replies: 7Last Post: 23rd May 2013, 18:28 -
Copy dual layer dvd
By Gerald Sr. in forum DVD RippingReplies: 7Last Post: 3rd Mar 2013, 21:52
