I have a question. If you are using a PAL source that is 25fps, will using srestore on it with a setting of 25 like this "srestore(25)" even do anything at all? They are the exact same framerate and srestore was supposed to be helping to remove blended/ghosted frames.
Results 1 to 12 of 12
You'll have to run a deinterlacer before srestore to notice any improvement. Using Yadif or QTGMC before srestore you turn each field into a new frame. With this doubled frame rate srestore would likely be able to find fewer blended frames and return the frame rate to the original 25.
Although there are omode parameters to srestore which accomplish deblending through other methods. -
Which you neglected to mention in the earlier post? I, for one, thought you were asking about using SRestore without a bobber before it.
Is this some sort of a hypothetical question (once it becomes clear what the question is)? If you have a specific video in mind, then please make a sample available. -
It was an animated series that originated from NTSC. Problem is, only PAL got a DVD release and I was trying to get it more like 23.976fps with reduced blends in it. So I was using a QTGMC + srestore combination to get that result. I just wondered if srestore set at 25fps would even have any effect on the source at all since the source was 25fps on the DVD. Someone was trying to tell me that I should always use srestore(25) on PAL sources, but I have used srestore(23.976) and its been fine for me.
If the video was actually sped up to PAL speeds and it still ended up frame blended then you would use srestore(frate=25) with an assumefps(24000/1001) at the end of your script. If the video was not sped up and the studio just dumped a 23.976fps video directly to 25fps PAL, then you would use 23.976.
But manono is right. A sample would really clear this up. -
SRestore discards blended frames preferentially to give the frame rate you specify (or the default rate). If you give it 25p and ask for 25p it will do nothing. If you give it 50p (from Yadif(mode=1 or 3) or QTGMC()) it will discard the 25 frames with the most blending out of every 50. If you specify too low a frame rate it will discard non-blended frames, leaving you with a jerky video. If you specify too high a frame rate it will leave some blended frames, again leading to jerky video.
If you provide a sample, include a long panning shot.Last edited by jagabo; 30th Jan 2018 at 18:16.
Yes, I meant to write frame rate, not bitrate. I'll fix the post so as not to lead to confusion.
How to improve chances of SRestore blend detection?
By ndjamena in forum Video ConversionReplies: 52Last Post: 7th Aug 2025, 14:30 -
A/V sync issues: MeGUI + AVISynth - PAL to 23.976 w/ QTGMC + Srestore
By U2Joshua in forum Video ConversionReplies: 6Last Post: 17th Dec 2016, 11:29 -
How do I use SRESTORE
By DaneClark in forum EditingReplies: 2Last Post: 4th Oct 2016, 21:32 -
My second DVD conversion - use SRestore or not?
By pooksahib in forum Video ConversionReplies: 10Last Post: 16th Apr 2016, 08:28 -
AVISynth / sRestore not removing duplicate frames
By bvdd in forum Video ConversionReplies: 4Last Post: 23rd Nov 2015, 07:08
