My new Sony FDR-AX33 camcorder’s native format is 4K, which we don’t need for our church youtube postings. To get the regular HD, it seems I have to use AVCHD format. The Sony software “PlayMemories” does a good job of exporting multiple (17 minute) files into one MTS HD file (1920x1080), but that still results in a huge file on my limited SDD memory on the Mac. I wish the software would let me export to the 720 size as well as mp4 in one step. But it doesn’t have that option.
If I use VLC or Movavi Video Converter, they can see the underlining files in the AVCHD folder, and convert them as desired, but for some reason, when I merge the 17 minute parts, the joining leaves a 1/2 second gap which I have to manually smooth out - as opposed to the PlayMemories export which seamlessly puts them together.
My workaround: use the USB cable to connect cam to mac and use PlayMemories to export to a SDD card, and then Movavi to convert the resulting MTS to mp4 of the 720 size. But that is so clumsy!
I tried the idea of a named pipe or fifo in Unix to hold the intermediate step, but that only works from the command line in a terminal. Sigh.
Any ideas without buying more software? Thanks. Boyd
	This seems to suggest that it would be possible to have the camcorder record in MP4 format with 720p resolution?Originally Posted by https://www.sony.com/electronics/handycam-camcorders/fdr-ax33/specifications
	I'm betting that the XAVC-S 1080p60 option would retain better quality for your youtube postings, and you would likely be able to retain single files, as you would be bypassing AVCHD's compartmentalized structure. And with ffmpeg, you could convert directly to another rez or format if necessary on Mac in one step.
 But for goodness sakes, find a better app than "Play Memories" to do your work with. It's like using a toy hammer.
  Do I need to convert photos to 720 by 480 before converting to DVD format?By johnharlin in forum Video ConversionReplies: 13Last Post: 4th Dec 2015, 17:15
  How do I convert MP4 to AVCHD?By rnaval in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Nov 2015, 03:50
  Need to convert MP4 to FLV format and can't seem to be able to :-(By shauniedawn in forum Newbie / General discussionsReplies: 11Last Post: 20th May 2015, 11:51
  Convert to MP4 formatBy dvrvarma in forum Portable VideoReplies: 7Last Post: 7th Mar 2014, 13:09
  Which format to record? AVCHD or MP4?By vid83 in forum Newbie / General discussionsReplies: 13Last Post: 12th May 2013, 20:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
