Many burning software keep nagging about the unknown end of the last track for CUE sheet files.
How can I edit a CUE file to specify an end?
Results 1 to 10 of 10
Marsia MarinerGuest
According to the file Cdrwin.hlp, no cue sheet specifies the "end" of the last track of a compact disc.
So you'd better find and use only decent disc-writing software. -
Don't know which software you're using, or how you have your CUE sheet set up, but there shouldn't need to nor shouldn't be an "END" specified. Look up CDRCue or CueMaster CD cuesheet editors, as they both put out legit cuesheets that any self-respecting burning app ought to support.
Doh, Marsia Mariner beat me to it.
Scott -
"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
[QUOTE=Keyser;2510258] Whoops, InfraRecorder and CDburnerXP do not, unfortunately. Linux burners not tested yet.
Let's try ImgBurn and AnyBurn. -
Let's also try showing your cuesheet, because I've never had any issues with CDBurnerXP, which makes me think your cuesheet syntax is malformed.
Scott -
No, CDBurnerXP fails on the FLAC.
InfraRecorder fails reviewing the CUE sheet due to unknown end. -
Converting TrueHD Atmost track to Dolby Digital + Atmos track?
By illuvattarr in forum AudioReplies: 2Last Post: 21st Jul 2018, 23:09 -
Low end system high end hevc compression
By Delibit in forum Video ConversionReplies: 3Last Post: 21st Jun 2016, 17:51 -
How do I (BATCH) set a specific subtitle track, and audio track as default?
By MountainSplash00 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2014, 06:53 -
VideoStudio Pro x6 - Link title track to video track
By hyzerfool in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2014, 09:28 -
Combine two SUP subtitles end to end
By Zestanor in forum SubtitleReplies: 5Last Post: 22nd Feb 2013, 20:45
