Results 1 to 10 of 10
    Feb 2008
    Portugal
    My browser is Mozilla Firefox.
    When I initialize it the search engine is automatically DuckDuck. What must I do to eliminate
    this malware and return to my Google Search?
    Thanks for your help.
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    Just click on magnify glass in search window. Duckduckgo in some cases has better results than google, because google censored it.
    Edit: or in option search default searchengine and change here are 100% permanent.
    Bernix
    Aug 2006
    This is what worked for me:
    Click on the Menu icon, located in the upper right corner.
    Click "Options".
    Click"Search".
    Select "Google" from the drop-down menu under "Default Search Engine".
    Bernix's method is faster:
    Click the Magnifying Glass icon in the search box.
    Click "Change Search Settings"
  4. Member Bernix's Avatar
    Apr 2016
    Europe
    And call it malware is bit strong... Have you any evidence?
    VirusTo... reults
    Bernix
    Apr 2017
    England
    DuckDuckGo is not malware, it is a fine search engine that doesn't track you. I use it all the time.
    Feb 2008
    Portugal
    usually_quiet: Thanks for your help.
    Bernix : I donīt know very well what is malware. But if you say
    it is better than Mozilla with some issues, the next time I will
    try DuckDuck.
  7. Member Bernix's Avatar
    Apr 2016
    Europe
    @DeJay
    I understand there might be some pressure from major companies or rather company to make such illusion OP seems to be victim of it.
    Bernix
  8. Member Bernix's Avatar
    Apr 2016
    Europe
    try DuckDuck.
    Sorry don't understand what you mean. DDG is search engine, and pretty good. It has nothing to do with Mozilla.
    Bernxi
  9. DuckDuckGo is better than Google if you care about your privacy - if you don't care about your privacy then change search engine.
  10. Member Bernix's Avatar
    Apr 2016
    Europe
    for some search it doesn't filter results like google does. But already mentioned. I mean FS services and similar, hope you understand what I mean. But don't use it for this, just don't wanna be tracked, but still am.
    Bernix
