Results 1 to 22 of 22
    Jan 2018
    Nederland
    hi
    I have a usb with a direct recording of my ultrasound (baby) on it, but it wont play, we tried every player en codec but it wont play.
    if it wont play, its lost for ever, so i really hope somebody can help me.
    If i put the usb in de computer, you can see there is data, but when opening the file is not recognized.
    if you need anymore information please let me know, iam a mother with very little computer nolege, so please quick it simple if i have to do anything
    THANK YOU!
  2. Member Bernix's Avatar
    Apr 2016
    Europe
    Hi,
    you can try open your file in avidemux, it is program for conversion of videos, or in handbrake. In handbrake it can tells you it contains or not DRM. And all players you mean VLC, Potplayer, MPC-BE ? which are probably biggest players nowadays.
    Also you can post text form of Mediainfo of the file.
    Edit: probably protected video, but it shouldn't be from your description
    Bernix
    Jan 2018
    Nederland
    Thanks for you quick reply!
    yes I tried vlc its not working
    text mediainfo :
    Algemeen
    Volledige naam : F:\Encode_1080P_185.mp4
    Formaat : MPEG-4
    Formaatprofiel : Base Media
    Codec-ID : isom (qt )
    Bestandsgrootte : 758 MiB
    IsTruncated : Yes
    i will try avidemux now
  4. Member Bernix's Avatar
    Apr 2016
    Europe
    Text report from mediainfo should be more descriptive.
    When you are in Mediainfo - View - Text
    It seems to me you are in tree view.
    Bernix
    Jan 2018
    Nederland
    i installed avidemux abd tried to open the file, but its not workin
    attempt to open failed and cannot find a demuxer
    Jan 2018
    Nederland
    is this the text you mean from mediainfo ? :
    Algemeen
    Count : 329
    StreamCount : 1
    StreamKind : General
    StreamKind/String : Algemeen
    StreamKindID : 0
    Inform : MPEG-4 (Base Media): 758 MiB
    CompleteName : F:\Encode_1080P_185.mp4
    FolderName : F:
    FileName : Encode_1080P_185
    FileExtension : mp4
    Format : MPEG-4
    Format/String : MPEG-4
    Format/Extensions : mov mp4 m4v m4a m4b m4p 3ga 3gpa 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma ismt f4a f4b f4v
    Format_Commercial : MPEG-4
    Format_Profile : Base Media
    InternetMediaType : video/mp4
    CodecID : isom
    CodecID/String : isom (qt )
    CodecID/Url : http://www.apple.com/quicktime/download/standalone.html
    CodecID_Compatible : qt
    Codec : MPEG-4
    Codec/String : MPEG-4
    Codec/Extensions : mov mp4 m4v m4a m4b m4p 3ga 3gpa 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma ismt f4a f4b f4v
    FileSize : 794804224
    FileSize/String : 758 MiB
    FileSize/String1 : 758 MiB
    FileSize/String2 : 758 MiB
    FileSize/String3 : 758 MiB
    FileSize/String4 : 758,0 MiB
    StreamSize : 794804224
    StreamSize/String : 758 MiB (100%)
    StreamSize/String1 : 758 MiB
    StreamSize/String2 : 758 MiB
    StreamSize/String3 : 758 MiB
    StreamSize/String4 : 758,0 MiB
    StreamSize/String5 : 758 MiB (100%)
    StreamSize_Proportion : 1.00000
    HeaderSize : 28
    DataSize : 794804196
    FooterSize : 0
    IsStreamable : No
    File_Created_Date : UTC 2014-04-10 22:38:56.000
    File_Created_Date_Local : 2014-04-10 23:38:56.000
    File_Modified_Date : UTC 2014-04-10 23:03:26.000
    File_Modified_Date_Local : 2014-04-11 00:03:26.000
    IsTruncated : Yes
  7. Member Bernix's Avatar
    Apr 2016
    Europe
    Sorry I have not experience with apple quicktime. Probably someone other helps you with this. But you can install iTunes or apple quicktime, which i don't want nor testing.
    It seems to me you have to install this software, but i wouldn't recommend it. But if the video is for you invaluable, you can try this.
    Bernix
    Jan 2018
    Nederland
    thanks, but i also tried quicktime player it not working.
    And i just tried handbrake it wont open (see attached file)
  9. Member Bernix's Avatar
    Apr 2016
    Europe
    That's why i suggested Handbrake too, there is possibility it has DRM and it is copy protected file. If quicktime doesn't helps you I can't see any chance, but probably someone will helps you better.
    Bernix
    Jan 2018
    Nederland
    Thanks Bernix, yes hope so too that someone else can help me or has any other ideas.
    thank you for your time!!
    Feb 2006
    Try dvdfab media player - https://m.dvdfab.cn/media-player?trackID=navmenu
    Jan 2018
    Nederland
    tried dvdfab media player, it looked like it was loading, but its not working..
    i can almost cry...
  13. Member Bernix's Avatar
    Apr 2016
    Europe
    The media info URL clearly states, it is related to apple quicktime codec. I think if not playable in newest Quicktime version, it will not play at all. Probably some sort of protection there. If is it ultrasound, shouldn't contain any protection. Ask nurse or who did it. As last resort I suggest you to check if usb wasn't badly removed. Right click on drive and there something like repair... I don't even know, if is it recent record (hope can be write again in next session) or is it old record Now I see it is 4 years old recording. Weird is they are using apple format for their clients. Should be in more common format.
    Bernix
    Jan 2018
    Nederland
    no the recording was made in noveber 2017, they (the pratice) said the recording on the usb is not protected, and normally you can play it in all media players, they mostly use powerdvd or windows media player and it loads instantly, the never use quicktime...
    the practice also looked and it did not load on that systeem also, they said it changed, that it now sais quicktime because of us trying at home..
    They said it never happed before, normally when there is an error there is nothing recorded and the files are empty, but this video file is not empty...
    They called the usb comapany and they said it can happen 1 in 5000 that there is something wrong with the usb and there is nothing you can do about it...
    so the recording on the usb is from 2017 and i have the newest quicktime player installed
    Jan 2018
    Nederland
    i also tried recovery and repair, but nomistakes are found
    Feb 2006
    i also tried recovery and repair, but know mistakes are found
    Try copying the files to a CD or dvd and see if you can get them to play.
    Aug 2013
    Central Germany
    Suspicious field:
    IsTruncated : Yes
    Also, there are no details about content streams (neither "Video" nor "Audio"), only the "General" block about the container.
    I would assume that this file is incomplete, and the "headers" describing the content were in fact at the end of the file; now they are lost. No chance to repair this QuickTime based MP4 file. Is it possible that this USB stick was prematurely removed, before the recording was written completely?
  18. Member
    Jan 2018
    Nederland
    I tried burning the videofile on a dvd, but it also not working
    As far as I was told the recording on the usb was complete, because otherwise the file would be empty and they told me that is not the case.
    Normally when a recording went wrong the usb is empty, this is the first time a recording is on the usb and you can also see the data, but its not playing.
    They told me its the first time in 1000+ recordings, so maybe they are right and itis just a bad usb (production error), they buy them in bulk.
    I tried a million things now, nothing is working, I think its just lost
    Aug 2013
    Central Germany
    No promises, just a Google search result: recover_mp4 or as online service: http://restore.media/
    In theory, it may be possible to recover at least the video stream if you make assumptions about its content format, and analyze contained additional headers in the video stream. Until now, I never found any tool which attempted to be smart enough about it. But if you are pretty sure that the contained video should be H.264, give it a try.
    _
    P.S.: It requires a good recording with the same resolution to copy header data from and apply them to the corrupt video. So if you can get a brief second clip, you may be lucky to transfer its characteristics and recover some part of it.
    Jan 2018
    Nederland
    Thank you LigH.de, i emailed them both, hope they can help!!
    Jan 2018
    Nederland
    WHoe WHoe, I am very happy because it worked!!
    The online service was able to restore the whole 20 minutes (just 2small bad moments)
    Very happy, I really lost all hope, so many hours trying to get it to work and asking for help and this finally and only worked!
    LigH.de thank you very much again for recommending them to me , october262 and bernix thank you for your help too!
  22. Member
    Aug 2013
    Central Germany
    Rather thank the developer of recover_mp4 (possibly with a little donation); all I did was having a good guess selecting a Google search phrase.
