Let's assume that the DVD/BD stream was MPEG-1 unexpectedly, instead of MPEG2/H.264/H.265-HEVC?
How would a DVD/BD player react?
Depends:
1. Dvd player - if it is dvd-compliant mpeg1 using constrained bitstream parameters, and D1, 1/2D1 or 1/4 D1, and is properly & muxed & compiled, it ought to just play it (as that is part of the dvd spec). Not compliant, won't play.
If is just a file, depends on the model & the "general media player" capabilities of that chipset and the licensing.
2. If BD player, mpeg1 is not compliant with any part of the bd spec, so unless it falls into the same category as the 2nd part above, it won't play it.
These days, due to the increasing time distance from when s/vcd was even considered a half viable option, there is little to no incentive for a manufacturer to include support in general media list for mpeg1, either authored (vcd) or not.
Scott -
According to this page (not any relation to this page) some do and some not. I suppose you mean stand alone players. And as mpeg1 usual file.
https://www.bestadvisor.com/blu-ray-players
Bernix -
MPEG-1 is foundation for VCD - first modern consumer digital video standard - if device provide VCD support then MPEG-1 VCD compliant content should be played without problems...
True, @pandy. But many, many maufacturers no longer support vcd any more.
Example: I have 3 different bd players in my house, from 3 different manufacturers (vizio, lg, samsung) and none of them support vcd. Only a used sony dvd player that I got at a thrift store does. It's probably worse here in the US where vcd never took hold of consumers, vs. internationally, but that is certainly still the trend.
Scott -
IMHO MPEG-1 should be playable without issues in multimedia mode by sufficiently modern HW player - perhaps with some limitations (such as lack of support for UHR on MPEG-1 - till H.264 - MPEG-1 was one of few codecs capable to support 4096x4096 video)
I can't handle this DVD, please can you help me?
By TeNSoR in forum Newbie / General discussionsReplies: 11Last Post: 3rd Jan 2018, 20:21 -
How to handle 4K footage when editing for DVD?
By kieranvyas in forum Authoring (DVD)Replies: 4Last Post: 23rd May 2016, 12:15 -
Do any sony 3d bluray players handle sbs material?
By yoda313 in forum Off topicReplies: 5Last Post: 30th May 2014, 16:35 -
DVD player does not handle 4:3 video to 16:9 TV gracefully
By impmon2 in forum DVD & Blu-ray PlayersReplies: 13Last Post: 17th Dec 2013, 21:31 -
How do i know if my pc can handle.....
By SE14man in forum Newbie / General discussionsReplies: 2Last Post: 26th Apr 2013, 01:19
