Hi, is VSDC capable of after editing HEVC h.265 codec 60fps video files can also save in the original format? What are the best result settings & is the out come better if changed to lower frame rates? How much of a degradation of video quality after editing if any? Can AVC h.264 convert to HEVC h.265 codec? Thx, all advice is appreciated.
Hi Wilson,
If you're talking about the original format, then of course. Simply add your file using the "Import content" button and the same settings will be applied for the project.
And while we're still on the subject, you can choose 100% quality in codec settings. If you decrease frame rate, the video won't get better/worse. Yet, if you make 30fps out of 60fps, you're likely to lose half of the frames, that's it.
On the output, the video will be decoded anyway, however, you can make it as close to the original quality as possible.
Re: Can AVC h.264 convert to HEVC h.265 codec - yes! Here is a how-to video to help you.
Zond 265, the first professional HEVC / H.265 Analyzer from SolveigMM
By DmitryV in forum Latest Video NewsReplies: 5Last Post: 13th May 2024, 10:02 -
Only Edge browser could play 8K 60FPS HEVC, other browsers & players crased
By Stears555 in forum Software PlayingReplies: 20Last Post: 12th Nov 2017, 15:36 -
Issues to save an output file, MKV, HEVC (H.265) on VirtualDub FilterMod
By ResetMaster in forum EditingReplies: 5Last Post: 30th Aug 2017, 12:40 -
HEVC x.265 conversion ?
By joecass in forum Newbie / General discussionsReplies: 13Last Post: 31st Dec 2016, 08:09 -
theX.265 (a free HEVC) codec. Have you ever tried that HEVC encoder? (HELP)
By Stears555 in forum Video ConversionReplies: 41Last Post: 16th Sep 2013, 12:15
