Help me pls how to Encode like this
What encoder app they use?
what setting they use?
720p Only 37MB video link : https://sendit.cloud/bvobu7lc33yg
480p only 23MB video link : https://sendit.cloud/y2dfal3ckhvj
their site :http://www.98subs.com/aho-girl-episode-9-subtitle-indonesia/
Hi,
you can get their settings using Mediainfo text report. It is very easy to compress such content for anime in x(h)265. It is very effective. Not surprised with size and "quality"
Edit: if you want have some GUI with full control of x265 you can use ffmpeg, or GUI for example Avidemux.
BernixLast edited by Bernix; 27th Jan 2018 at 07:36. Reason: EDIT
as a side note: often the magic isn't in some encoder setting, but in the filtering done before the encoding,... (no there is no way to know those filters and the settings they were used with by looking at an encode)
users currently on my ignore list: deadrats, Stears555, marcorocchini -
But of course good denoise filter using can help a lot. It depends on your source. Also in this sort of animation as much as possible reference frames helps lot for sure. They used subme 3 it is in HEVC enough, but with higher value you will also do not get worse results, but time of encoding will be longer. Much longer.
Also they used AQ-mode 2, with strength 1,80 which is probably very useful with anime.
Also note they used x265 Constant rate factor (CRF) 31, which isn't much quality oriented, but for anime good enough if you are satisfied with result.
Bernix
Simple x264/x265 Launcher encode log
By leghorn in forum Newbie / General discussionsReplies: 2Last Post: 24th Mar 2017, 06:13 -
encode w/out the 'perception' benefit of x264 and x265
By vhelp in forum Video ConversionReplies: 9Last Post: 7th Nov 2016, 04:45 -
How To Encode x265 Like This ?
By iyanricardo in forum Newbie / General discussionsReplies: 5Last Post: 16th Jul 2016, 12:06 -
Is it possible to mux/pack x265 to x264 without re-encode?
By sleep0 in forum Video ConversionReplies: 4Last Post: 2nd Dec 2015, 00:41 -
Color issue in x265 encode
By Evad3R in forum Video ConversionReplies: 48Last Post: 6th Mar 2015, 14:25
