Are there any 4K TV/monitors available yet? I am not asking for a 4K TV, but a 4K monitor with a built-in TV tuner.
Results 1 to 14 of 14
What kind of tv tuner DVB-S, DVB-T, DVB-T2?
There are 4k monitors available, but I don't know if these have any kind of tuner built in.
But it doesn't matter, take a small linux box to do the job, but you need of course 2 ports (1 HDMI for Box and one HDMI/DVI/DP for PC) if plugged in directly. -
DVB-T or DVB-T2. I already tried a box (not linux) on my current monitor and picture in picture was not working correctly. I know I can use a DVB-T USB stick under windows, but I prefer a standalone solution.
try a linux box, these devices work much better than any other standalone device.
I can recommend VU+ -
I'm afraid you will be disappointed - i was able to find only this https://tweakers.net/categorie/344/monitoren/producten/#filter:TcsxDoAgEAXRu_yaApZlVQ5...xWRtUAJTq2r9AA as 4k or higher with some TV tuner (but not analogue one).
External but separate tuner box (set top box) will be probably best option.
Anyway you can use similar search site in your country - just go for section monitors and select desired functions - probably best approach. -
Nothing with a built-in TV tuner. I am however tempted by the 2k monitor in the link below, which for about half the price could hopefully be a worthwhile upgrade from my current full HD monitor.
http://eu.aoc.com/en/products/q3279vwf
If only I could check it in person before buying.Last edited by kyrcy; 11th Feb 2018 at 12:33.
Beware with standalone pc monitors and "watching tv" that you don't run into framerate issues.
most monitors only do 60 Hz, a TV normally suports refresh rates like 23Hz/24Hz (23,976) / 24Hz / 25Hz / 29Hz/30Hz (29,97Hz) / 30Hz / 50 Hz / 59Hz/60Hz (59,94Hz) / 60 Hz
Many monitors will accept input at 50Hz as well as ~60Hz, but most monitors don't do a good job at scaling video to match their native resolution and don't like interlaced input.
Maybe an Android TV box would work. I know many can output UHD video, but I'm not sure about 2K and WQHD resolutions The WeTek Play 2 is discontinued now, but could be equipped with a TV tuner module. Perhaps something similar from another maker still exists. I have also seen some TV tuners intended to be used with Android devices.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
I know there are 4K monitors for gaming that have variable refreshrates/adaptive syncing. But I can imagine it only working with G-Sync/FreeSync videocards and not with tv-settopboxes, mediaplayers and such.
TV set-top boxes can often be set to output video at a fixed resolution and and frame rate over HDMI. The problem is that many only go up to 1080i, which is fine for a TV but not usually for a monitor.
I did some research, and found configuration screens for at least one Android TV box (Xiaomi Mi Box) showing that its HDMI output could be set to a fixed resolution and refresh rate, similar to other computers. The "4K2K" refresh rates for this particular model were listed at 24Hz and 30Hz. An Android TV box with HDMI 2.0a out should be able to output 2160p and 1440p at 60Hz, if I'm reading the supported resolutions chart for HDMI 2.0a correctly.Ignore list: hello_hello, tried, TechLord, Snoopy329
Control PotPlayer on Monitor 1 play video on Monitor 2
By CyberDude4819 in forum Software PlayingReplies: 4Last Post: 5th Dec 2014, 10:16 -
PC Monitor
By andy jackson in forum Newbie / General discussionsReplies: 20Last Post: 19th Nov 2014, 10:27 -
No Monitor
By John Hod in forum Newbie / General discussionsReplies: 8Last Post: 23rd Feb 2014, 18:31 -
Which is better for me a Monitor or TV?
By mikehende in forum Newbie / General discussionsReplies: 15Last Post: 18th Apr 2013, 12:28 -
HD Monitor or HD Tv ?
By DB83 in forum ComputerReplies: 55Last Post: 6th Apr 2013, 13:23
