Hi
I have DVD Shrinked a Bonus DVD full of extras and an extended finale of the final episode of a series. I have not compressed it just a straight rip. The problem is when I use Handbrake to separate the video titles of the ripped DVD so I can make an MKV for just the extended finale any title I extract is just the original final episode. I assume this is because of the IFO file tracking information when I load the VIDEO_TS directory into VLC Player and click the Extended episode when the extended scenes play the duration of play tracking bar changes from the duration to 0.00 played out of 0.00 and once the scene finishes it returns to normal tracking for example after extended scene finishes it returns to 26.13 played out of 55.43 video duration. I have downloaded IfoEdit and PgcEdit to see if I can work out which titles I have to burn and then will join them but have had no success. Any ideas thanks in advance.
Try PgcDemux to get the individual titles.
[Attachment 44501 - Click to enlarge] -
Thanks for the quick reply. When I load up the VTS_01 IFO I assume this loads up the titles present in the VTS_01 VOB file? As you can see in the screenshot vts1.jpg there are two titles which are the same length of which one is the normal final episode and one is the extended final episode. When I load up VTS_02 IFO there are loads of 40 second to 2 minute tracks seen in screenshot vts2.jpg which will be the extended scenes I assume which intersect throughout the final episode and make it the extended episode. Is there an easy way of finding out in what order and what scenes and when is the VTS_01 track selecting VTS_02 tracks and replicating that into a video file?
[Attachment 44504 - Click to enlarge]
[Attachment 44505 - Click to enlarge] -
First you should tick "Create a PGC VOB"
No. Or most likely not.40 second to 2 minute tracks seen in screenshot vts2.jpg which will be the extended scenes I assume
As I understand you have the choise of either playing a "Normal"episode or an extended.
I would expect those to be in your Titleset 1 (VTS_01)
As you cannot jump directly from one Titleset (VTS_01) to another (VTS_02) it's unlikly they are mixed.
Also note that instead of demuxing on PGC level you can demux on cell level if needed.
How to rip a bonus disc so things are in the right order?
By kelemvor in forum DVD RippingReplies: 2Last Post: 21st Dec 2017, 23:08 -
Encode only Bonus material in DVD Rebuilder
By walruss in forum DVD RippingReplies: 9Last Post: 25th Jul 2015, 17:08 -
Can i hold 480p(bonus) with 1080p(movie) when i remux file?
By ningnong132 in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Apr 2014, 08:37 -
Problems backing up Extended Play CD
By Seeker47 in forum ComputerReplies: 17Last Post: 17th Mar 2014, 12:24 -
Need help cleaning up a couple dark videos [Bonus $]
By tkf in forum RestorationReplies: 28Last Post: 10th Dec 2013, 17:28
