I usually consider the latest official driver as the best driver available, but is this always the case? Or should I stick with the latest driver provided by the motherboard manufacturer instead of the latest from Realtek? I currently have 6.0.1.8186 installed. With this the front audio panel does not seem to work and audio mixer is not listed under Sound.
I always take risk to install latest available driver - nowadays HW vendors usually not going over default application and as such generic drivers works quite fine.
Personally i can recommend this site http://www.station-drivers.com/index.php?lang=en using it from many years (10++) -
For some reason the latest official driver (0009-64bit_Win7_Win8_Win81_Win10_R282.exe) does not install the Realtek HD Audio manager. The latest driver (6.0.1.7727) from the motherboard manufacturer installs it. Any ideas why?
Analyse .inf files - check if your hardware is supported by driver - search for strings similar to this "Realtek High Definition Audio" = IntcAzAudAeModel, HDAUDIO\FUNC_01&VEN_10EC&DEV_0270&SUBSYS_103C1445 but matching real id of your HW (probably best idea is to search file locally in folder with string copied from HW manager). -
since I moved to Win 10 long time ago (already Insider Preview before official stable launch), I use default M$ driver, which works just fine for Realtek Audio "cards"
In my experience drivers directly from Realtek offer more features than Microsoft's or OEM's default drivers. But the quality isn't much different.
Capturing VHS to PC with a high definition resolution...?
By dark_myuutwo in forum Capturing and VCRReplies: 108Last Post: 10th Jun 2016, 11:18 -
High definition FLV to WMV (XviD4PSP?)
By Mughi in forum Video ConversionReplies: 2Last Post: 17th Nov 2015, 16:45 -
how to remaster an old video into High Definition?
By kenny1999 in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2015, 17:28 -
Old films to high definition?
By therock003 in forum RestorationReplies: 39Last Post: 1st Jan 2015, 08:27 -
Can standard DVD's be ripped to high definition?
By zBernie in forum DVD RippingReplies: 10Last Post: 3rd May 2014, 23:42
