I currently edit in 1080p but if there's one under $1000 that can handle 4k that would be great
Sent from my VS987 using Tapatalk
				Results 1 to 12 of 12
	Delay your purchase till Meltdown and Spectre impact will be completely known - https://meltdownattack.com/
	I know, it is speculative, but reading this links makes me calmer.
 https://www.techspot.com/article/1556-meltdown-and-spectre-cpu-performance-windows/
 and
 https://cloudblogs.microsoft.com/microsoftsecure/2018/01/09/understanding-the-performa...WeHcm0ft.mA)()
 Main impact is excepted at SSD discs, about 20%-35% glad still have magnetic discs. Don't mining bitcoin another thing that can be affected (security keys) and not running Virtual machines.
 So having skylake, feeling is overall o.k. but with older machines, impact will be bigger of course.
 If possible i wouldn't allow patch my comp, but i think it will be mandatory...
 Bernix
	Well... seem this is bigger issue and most processor architectures using speculative execution is affected to point where only one way to reduce/eliminate risk will lead to disabling speculative execution - loss of speed will be proportional to code quality and code that designed to be explicitly executed should be not affected. I believe this something deeper than SSD or bitcoin mining - this vulnerabilities addressing foundation of modern CPU's - speculative execution was one of keys to significant processing gain.
 I have no intention to install any patch as simply will not accept performance loss and don't believe that suing Intel for all my 7 computers has any chance to success however i'm almost sure that in future i will not buy anything from Intel as seem Intel was aware of this vulnerabilities from very long time yet they didn't take any serious action to solve this problem - simply lost interest to buy Intel product as over last 20 years Intel began to be a company offering bad quality products. Going for FPGA i will for sure not go for Altera (Intel owned) and now i will for sure not buy Intel CPU.
	Not sure if this is about it, but think it is. Check the date. Or is it some other vulnerability some absolutely different? And AMD is also affected, isn't? Even Nvidia rely on CPU somehow, mentioned in article. There should be some compensation from companies, when they sold crappy CPUs.
 Under Bios from asus site.
 [Attachment 44491 - Click to enlarge]
 Sorry me for not known too much but it seems to me it is some action against it.
 Probably wrong.
 Bernix
	So, i was wrong. my friend told me it was another issue, that I posted screen. Also Meltdown somehow solved (clearing cache), but problem is Spectre. What intel patched makes it worse, so now is suggested to go back, before this patch. AMD do nothing according to his report, and it is best can be done for now.
 Bernix
	That's why i strongly advise to relax and wait until situation clarify - also Intel and AMD response will be good on future shopping decisions. One or two months and this should be clear.
 And yes, ME or AMD PSP are another vulnerability however there is no performance impact expected after patching those vulnerabilities (Intel ME or AMD PSP are hardware+software solution of additional computer on your CPU that allow to control remotely your computer and your data - very good for NSA as it can be controlled remotely even without your permission and sadly i must say it is very difficult to turn it off - in fact at present day you are not allowed to disable ME as it control boot stage of your CPU and special procedure is required to achieve idle ME state - https://wiki.gentoo.org/wiki/Sakaki%27s_EFI_Install_Guide/Disabling_the_Intel_Management_Engine )Last edited by pandy; 25th Jan 2018 at 19:37. Reason: Intel ME
	It's my understand that, on a scale of 1-10, the risk is actually low for home desktops/laptops/tablets, like a 2.
 The real problem is always connected public servers (aka "clouds").
 And smart phones, since their security has always sucked.
 You'd have to be infected with malware first, so normal safety practices should hopefully keep you fine. Browsers have already been patched for it, and I'm already using ScriptSafe (because NoScript now sucks) and a strict firewall.
 The "patches" seem worse than the exploit, causing permanent damage to your system. And most may never have patches anyway.Want my help? Ask here! (not via PM!)
 As for today this is big unknown (at least from my perspective) - those vulnerabilities are very serious as potentially anyone can be relatively easily infected if for example JIT technology product is used (common situation for modern web browsers and JavaScript). It looks to me like end of era of "safe" computing Hardware - next generations CPU will be or slower or will return to "predictive" execution path for example EPIC architecture and this will be very serious challenge for example for compilers, perhaps this will require active programmers assistance to compiler, more work on checking and profiling code, definitely some aspects of programming will be affected by this and this may be a very painful exercise for programmers (i mean data flow aware coding - no more abstract coding and blindly relaying on compiler).
	Back to the OP's question. Specific suggestions for a laptop that can edit 4K?
  Which laptop for editing 4k video?By Plumber1 in forum EditingReplies: 9Last Post: 7th Jun 2017, 15:16
  Hello everyone. Laptop for 4k editing on premiere pro without proxies?By John1 in forum EditingReplies: 5Last Post: 6th May 2017, 16:19
  ReadyBoost on Win10; would USB3 provide real help in laptop video editing?By ahhaa in forum ComputerReplies: 3Last Post: 3rd Dec 2016, 17:53
  Hello from Newbie and Best Budget Laptop for video editing and playback ?By markallen5 in forum Newbie / General discussionsReplies: 7Last Post: 25th Oct 2016, 23:09
  Latest specs for a Laptop for video editing?By Bruce/Fl in forum ComputerReplies: 3Last Post: 1st Feb 2016, 22:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
