    Jul 2005
    europe
    Hello,
    I try to extract only the main movie from a bluray with menu etc with DVD Fab,
    That is ok.
    But now the problem.
    When it is original 24, when i play the burned disc on my sony bdp-s370, it is playing 60Hz.
    I have the same problem with more bluray discs
    When i play the original disc, it switch ok to 24.
    When i remux it in tsmuxer, the same.
    What can be the problem?
    Feb 2006
    try looking for a setting in your sony bdp-s370 or tv setting to change it to 24Hz
    Jul 2005
    europe
    it is not possible to change settings on my bluray player of tv
  4. Hi, please send us the disc files (except stream) and source&output bdinfo. We will check the reason.
    Or you can send those files to service@dvdfab.cn. you will get quick respond. Thanks!
