Hello. I am trying to write specifically a GUI utility to cut and splice a video and re-encode only the part in front of the key index frames. My thought is this will allow cutting a specific frames and not just at index frames. I can pull all the codec specifics like Cabac, deblock, etc. as well as size, bitrate, etc.. This leaves me with a couple questions.
1. Do I need to set all the parameters shown in MediaInfo codec settings need to be set, or can some of them be left out and still be compatible?
2. I know Cabac is set with the 'Loader=x' preset but I can find no information on setting 'analyze' or what the settings for it means.
If Anyone knows about this, I would greatly appreciate help with this information.(deblock=1:0:0 / analyse=0x1:0x111 / me=hex )
3. Does the re-encode portion need to be the same pattern such as IBBPIBBP or can it be different as long as it leads with an I frame such as IBBPIB making the segment IBBPIBBP -> IBBPIB -> IBBPIBBP {Re-encode portion in red}?
I'm sure I will have more questions before the utility works since my knowledge in this, even reading a lot, is limited so I will undoubtedly be back with more. I know many people have wanted this feature in a free program and I am hoping to create it and maybe add more codecs, VFR, etc. eventually.
Thanks in advance for any help.
Bud
1) not necessarily... But most parameters usually have an entry, even if it's omitted from the commandline
But sometimes even if the parameters match, x264 version matches, there are still problems with union...
1b) selur made a utility to match x264 settings from a mediainfo string, mis2x264 (and mis2x265 for x265)
What is loader=x ??2. I know Cabac is set with the 'Loader=x' preset but I can find no information on setting 'analyze' or what the settings for it means.
those mediainfo analyse results are --partitions i4x4,i8x8,p8x8,b8x8
No, can be different pattern as long as those adjacent GOP's are closed GOPs3. Does the re-encode portion need to be the same pattern such as IBBPIBBP or can it be different as long as it leads with an I frame such as IBBPIB making the segment IBBPIBBP -> IBBPIB -> IBBPIBBP {Re-encode portion in red}?
(Unless there are additional constraints , such as some device profiles, BD etc... might have certain frametype or GOP length constraints, along with VBV restrictions)
Looking forward to the utility! -
Great News! and Great work Selur. Half Work is done for me... now to make it GUI and work/ lol
Best x264 settings that you've ever tried
By anana in forum Newbie / General discussionsReplies: 4Last Post: 21st Apr 2016, 23:13 -
x264 Mediainfo to MeGUI x264 Settings
By Arugen in forum Video ConversionReplies: 2Last Post: 13th Aug 2015, 01:14 -
Information needed about video cassette.
By Crispan in forum Newbie / General discussionsReplies: 9Last Post: 17th Aug 2014, 12:09 -
What is the best settings for x264
By mmkk in forum Video ConversionReplies: 7Last Post: 14th May 2014, 11:11 -
MEGUI + x264 settings
By Cunhambebe in forum Video ConversionReplies: 41Last Post: 18th Apr 2014, 05:14
