I ran some anime through VidCoder to compress the x264 video to x265. It did that very nicely. The source files have two audio tracks, two subtitle tracks and three TTF font attachments.
Vidcoder lost the second audio track but kept the subtitles and fonts. I didn't really care about compressing the audio more. MKVToolnix v20.0.0 will work with these files. I can drop the original file and the new file onto it and deselect all but the video track of the new, deselect only the video track of the original and remux. Hooray, I have a lot smaller file.
BUT, it will be very tedious doing all of that mouse clicking. :P So I figured I'll batch strip all but the video from the new files with MKVBatch 1.3.2. Nope! It does *nothing*. It goes through the motions, nothing lands in the output folder. I've used it many times to batch mux subtitles, but only with one audio and one subtitle track.
How about MKVExtractGUI 2.3.0.0? Nope! All it shows are the three TTF attachments and like MKVBatch goes through the motions, does nothing. Just checked some other MKV files that don't have multiple audio or subtitle tracks. If they have chapters that's all it shows. No chapters, it shows nothing to extract.
Did updating MKVToolnix break MKVExtractGUI and MKVBatch? Muxing single subtitles with MKVBatch into video with single audio tracks still works, I've used it for that since updating MKVToolnix.
Yes, mkvtoolnix 20.0.0 broke some tools (don't know about mkvbatch, gMKVExtractGUI didn't break). So either go back to 19.0.0 for this operation or do it via command-line.
P.S.: VidCoder can handle multiple audio tracks just fine. It also has "pass-thru" mode so audio isn't getting recompressed unless desired by the user. -
I used gMKVExtractGUI to demux just the recompressed video, then MKVToolnix to replace the original video tracks with them. Hopefully the tools that have problems with 20.0.0 will get updates to fix them.
How to extract/cut parts from a mkv including all audio and subtitle tracks
By Baldrick in forum User guidesReplies: 23Last Post: 22nd Mar 2019, 12:00 -
How to protect subs in mkv from extraction/demuxing
By ZloyZloy in forum SubtitleReplies: 10Last Post: 29th Aug 2017, 01:41 -
Batch file to add multiple attachments to multiple MKV file.
By Rev3rse in forum Video ConversionReplies: 0Last Post: 6th Aug 2016, 00:12 -
DVD to .mkv/.mp4 w/ all Audio and subtitle tracks
By liquid65 in forum DVD RippingReplies: 2Last Post: 30th Aug 2015, 08:45 -
Compress MKV without Video/Audio/Subtitle quality loss
By Aravindtop in forum Video ConversionReplies: 14Last Post: 29th Apr 2014, 16:56
