  1. Today my MeGui not run perfectly
    I'm do everything but no success
    reinstall version but no work
    megui not encode audio and last 4th task
    Sent from my P4 using Tapatalk
  2. Your question is like asking a mechanic why your car won't start without him being able to look at it. It could be anything.
    Copy the contents of MeGUI's log file and add it to a post. It's fairly informative and will usually provide some clues.
    It's probably easiest to restart MeGUI, run a job that you know will fail, close MeGUI after it fails, then copy the entire contents of the newest log file in the MeGUI/logs folder.
