General
Unique ID : 118598960476052780755530409267285164455 (0x593954351C4DA86B1446E9D4298781A7)
Complete name : C:\Users\Vladimir\Desktop\01_Album_1_Svadba.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 3.91 GiB
Duration : 2 h 59 min
Overall bit rate : 3 115 kb/s
Encoded date : UTC 2018-01-23 15:55:01
Writing application : mkvmerge v20.0.0 ('I Am The Sun') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : AVC
Format profile : High@L3
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1 h 29 min
Bit rate : 5 715 kb/s
Width : 720 pixels
Height : 540 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.588
Stream size : 3.59 GiB (92%)
Writing library : x264 core 155 r2901 7d0ff22
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=17 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 40 ms
Stream size : 329 MiB (8%)
Service kind : Complete Main
Default : Yes
Forced : No
Results 31 to 38 of 38
Let's see
General
Complete name : D:\MarinaVid\VHS\01_Album_1_Svadba.mkv
Format : Matroska
Format version : Version 1
File size : 68.4 GiB
Overall bit rate : 54.5 Mb/s
Encoded date : UTC 2018-01-11 14:52:43
Writing library : DirectShow Matroska Muxer
IsTruncated : Yes
Video
Format : HuffYUV
Format version : Version 2
Codec ID : V_MS/VFW/FOURCC / HFYU
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:2
Bit depth : 8 bits
Language : English
Default : Yes
Forced : No
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Bit depth : 16 bits
Delay relative to video : -41 ms
Language : English
Default : Yes
Forced : No[ -
Greetings!
Faced with another issue while converting.
I attached pics. In first I see delay(?) in video track 85 ms. And audio delay in 40 and 40. I can't understand what does it mean, why two times? as in video track also 2 times.
In secoon unexplored values are 0 and 0. And audio 40 ms, as i set in properties of x264. Noticed desync. What am i doing wrong?
Thanks in advance.
[Attachment 44492 - Click to enlarge]
[Attachment 44493 - Click to enlarge]
p.s. How is it possible to capture video from VHS in command line, and it is possible? -
I assume first is delay from composition time 0. Second is delay relative to video delay. So audio is delayed 45ms. But because video is delayed 85ms audio actually starts 40ms before the video.
Thanks!
But i'm using setting of mkmerge -y 0:40
Full noticable delay...
Please explain me what formula tu use. I have input video delay in 85 ms, and audio -40 ms.
If two values of video is X1 and X2, audio Y1 and Y2. So what actions should I do?Last edited by Tarnum; 26th Jan 2018 at 03:41.
VirtualDub/AviSynth may have already gotten rid of the delay. At least that's what I would aim for when re-encoding. Can't answer without more info as requested in post #29.
Thanks a lot. But can't understand how to work witn AvySynth. In Virtual Dub no oppotunities to synchronise... Work stopped
MediaInfo not responding on Windows opening MKV with size over 40GB
Disc drive freezes PC when encountering damaged sectors. The SCSi deadlock.
By TechLord in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2017, 02:44 -
x264 conversion with Virtualdub/sony vegas 13 Color issues
By MajorFoley in forum Video ConversionReplies: 23Last Post: 20th Dec 2016, 07:11 -
Virtualdub ERROR CODE 512 ACMERR_NOTPOSSIBLE - DivX to Xvid in Virtualdub
By kurtky in forum Video ConversionReplies: 6Last Post: 4th May 2015, 13:26 -
x264 error
By yaston in forum Video ConversionReplies: 8Last Post: 9th Apr 2015, 05:59 -
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57
