QTGMC is a horrible deinterlacer because each frame shifts up or down by a line, which causes the video to flicker slightly. Is there a better deinterlacer out there?
				Results 1 to 10 of 10
	Maybe your source is the problem or you didn't use it correctly ?
 Normal interlaced video has a field offset. Each subsequent field goes up/down/up/down . A "smart" deinterlacer fixes this. A "dumb" deinterlacer leaves you with up/down motion similar to what you are describing
 Overall there isn't a better deinterlacer. Overall, QTGMC is the best for most situations (there are some exceptions).
 But if your source has special characteristics you might have to take another approach
	And if you post a sample, someone will probably make some suggestions as what would be appropriate for your specific video
	The bobbing is quite intentional. But it should not be visible; instead, it should be filtered and blended while constructing the full frames.
 I once had some visible flickering too, but it was caused by either outdated plugins or an unfortunate combination of calling parameters, I don't know for sure; but I got it fixed, and now QTGMC produces rock-stable results even for text screens with narrow stems.
	I've seen QTGMC do some odd things, but it's pretty rare and probably requires a non-typical source. I remember a video with a scene in a living room where there was an open fire burning, and for some reason QTGMC caused the fire-place to bob up and down while everything around it remained still, but I use QTGMC quite regularly and your experience definitely isn't typical. You probably should upload a small sample.
	- My sister Ann's brother
	You need to add SwapFields() before QTGMC(). But need to see the source to say for sure. Last edited by jagabo; 22nd Jan 2018 at 08:34.
  gpu deinterlacerBy themaster1 in forum RestorationReplies: 5Last Post: 10th Oct 2016, 09:03
  QTGMC errorBy bakonfreek in forum Newbie / General discussionsReplies: 13Last Post: 13th Dec 2014, 23:08
  Deinterlacer changing total frame count and overall length of the videoBy killerteengohan in forum DVD RippingReplies: 16Last Post: 15th Jun 2014, 15:56
  Using Avisynth MT with QTGMCBy agni451 in forum Video ConversionReplies: 11Last Post: 15th May 2014, 08:37
  How to optimize QTGMC deinterlacer for multicore?By brassplyer in forum EditingReplies: 3Last Post: 20th Jun 2013, 21:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
