I am trying to copy vhs tapes to dvd on this machine. I'm using dvd-r dvd's. I have followed all the directions in the manual, p-50-51. When I get to step #8 (DUBBING), the step which is supposed to start the process, I get the red circle with the slash through it..... the No Good entry, or not available symbol. Any thoughts on what I might be doing wrong? I've tried a couple of different manufacturer dvd's. Is there a preferred manufacturer?
Are these home-recorded VHS tapes?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
If the brand and type of DVD media you bought works for recording other sources, it should work for dubbing a VHS tape.
I have owned 2 DVD recorders but never a DVD/VHS combo recorder, let alone the one you have. If you followed all the instructions to the letter, the only thing I can think of is there is something wrong with the tape. Have you tried playing the tape to make sure it's OK?Ignore list: hello_hello, tried, TechLord, Snoopy329 -
The error symbol can mean one of two things: (a) The capture is too large to fit on a disc, (b) your VCR is transmitting false copy protection signals, which is a fault of the unit's low-quality player tbc (if a tbc circuit exists).
If you look over several years of posts in this and other video forums you'll soon get the idea that recording VHS to DVD with a so-so DVD/VHS combo gives you some of the worst quality possible. Don't throw away your tapes.- My sister Ann's brother
Toshiba
By Xil in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Aug 2017, 01:27 -
How Much Should A Used Toshiba RD-XS35 Cost?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 23Last Post: 4th Nov 2015, 23:54 -
Toshiba BDX1500KB
By enworb in forum Newbie / General discussionsReplies: 3Last Post: 2nd Feb 2015, 11:31 -
Toshiba SD-2700 Hacks?
By 2K1SilverCivic in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Dec 2014, 19:00 -
Toshiba DR430
By Jayman71 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 27th Jan 2014, 22:43
